clock-synced 16-Stage envelope generator
Page 1 of 1 [3 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Sat May 26, 2007 5:14 am    Post subject: clock-synced 16-Stage envelope generator
Subject description: Envelope rates in 16ths of the master clock
I read through the wishlist thread and saw the wish for clock-synced envelopes. So, here's my try:
It's a 16-stage envelope generator represented by two CtrlSeqs (for rates and levels), with rates scaled in sixteenths of the MIDI master clock: "0" = one sixteenth, "1" = 2 sixteenths, etc. (Don't input negative rate values, they will whack the circuit out of sync. If you want, you can add a diode module to prevent negative rates --I didn't do that, since I aimed for minimum mem% count.)
It uses 21,9% of memory --I couldn't make it more efficient. Hope it is useful nevertheless.
It doesn't have the sustain stage feature, as that would have complexified the design to the point of pointlessness (Laughing).
tim
16StageSyncEnvTK.pch2
16-stage envelope generator, rates scaled in 16ths of the MIDI master clock
 Filename:  16StageSyncEnvTK.pch2
 Filesize:  2.21 KB
 Downloaded:  1218 Time(s)
3phase
G2 patch files: 141
PostPosted: Sat May 26, 2007 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
one question... when negativ input is not allowed why the sequencer module is not set to unipolar mode?
Tim Kleinert
G2 patch files: 236
PostPosted: Sat May 26, 2007 6:08 am    Post subject: Reply with quote  Mark this post and the followings unread
...because then you get 0.5-increments.
