signal too hot on egroovz drum thing
Page 1 of 1 [2 Posts]
qinqongfrog
PostPosted: Sat May 26, 2007 8:45 pm    Post subject: signal too hot on egroovz drum thing Reply with quote  Mark this post and the followings unread
I'm bending this thing made by EGroovz, it has 5 drum pads on it, and little music loops. I found some cool bends, and I'm trying to add a line out (1/4), but the signal is way too hot.
What should I do? I tried putting a 1k resistor and a 10k resistor between the 2 wires that connect to the output jack, but it didn't do anything. I've also tried different pots and still, nothing. Thanks for any help.
Freddie Freelance
PostPosted: Sat Jun 30, 2007 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try a 1M trim pot & tweak it until you get a level you like.
Niio1
