Yusynth VC-LFO : adding exponential FM reponse
Page 1 of 1 [2 Posts]
funkyfarm
PostPosted: Wed May 30, 2007 6:19 am    Post subject: Yusynth VC-LFO : adding exponential FM reponse Reply with quote  Mark this post and the followings unread
http://yusynth.net/Modular/index.html
I plan to swap one MFOS VCO modified into LFO (not very satisfying…) by Yves Usson VC-LFO, which features a sync option.
A friend build it and it is great ; it’s been a long time we were seeking for a VC version of LFO around here…
But I have to admit there is something i’m about to regret.
My version of MFOS LFO has a optional switch which affects FM CV input response (LINEAR or EXPONENTIAL)…which is far from optional indeed.
Do you think it would be possible to implement linear control over this design ?
Sticking a BC547 npn transistor ?
 Filesize:  66.79 KB
 Viewed:  3628 Time(s)
yusynth
PostPosted: Wed May 30, 2007 11:35 am    Post subject: Re: Yusynth VC-LFO : adding exponential FM reponse Reply with quote  Mark this post and the followings unread
No replacing the PNP by a NPN would not work.
If you want a linear control the circuit needs a complete redesign. The way to do it would be to disconnect the emiter pin from the positive power rail,
insert a resitor in between, removing R7, disconnecting R5 from the output of the OPA and connecting R5 to the emitter and recalculate all the resistor values, you would have to redesign a complete PCB for it...
Yves
