"Throw" control
Page 1 of 1 [2 Posts]
Rix
G2 patch files: 25
PostPosted: Wed Jun 06, 2007 1:54 pm    Post subject: "Throw" control
Subject description: hold two values for throw control
history/inspiration:
These patches in Reaktor where you can "grab" a cursor and throw it in a x-y field, and it bounces back at the edges. Also seen in "Koan X" , Lemur Controller etc. You get the picture?
So we started with NoteOn's triggering S-H modules to get a value from the wheel.
We're having trouble scaling the noteOff value. This patch should work, why doesn't it?
Eventually we should derive a value from the difference from the NoteOn and Off value to use as a control for bouncing stuff. This would involve adding values and "wrapping" when max/min values have reached.
Any help will be very welcome..
Rix, electri-fire
ThrowControl.prf2
 Filename:  ThrowControl.prf2
 Filesize:  12.91 KB
 Downloaded:  1425 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Jun 07, 2007 3:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't quite understand what you are trying to do. Nothing is connected to the S/H-modules (except a "dead" LevAmp module, as nothing is going into that).
However -I got inspired by your post to make a XY-Pong building block. Perhaps this is of use to you in your endeavour. Here it is:
http://electro-music.com/forum/topic-18648.html
