Level modulation in mixer modules
Audio files: 215
G2 patch files: 92
PostPosted: Fri Jun 08, 2007 1:42 am    Post subject: Level modulation in mixer modules Reply with quote  Mark this post and the followings unread
I would love a modulation input for every regular input in the mixer modules, that worked like the AM input in envelope modules. I use the AM level module a lot with max modulation to regulate levels automatically, which is big and more expensive than I need (since I don't often use subtle ring modulation). MIDI control of the mixer knobs would be too low-res and also an extra unnecessary module.
If the modulation input is not used, the G2 compiler could detect that so that the mixer module isn't more expensive than it is now. It would be ok if there were just one, say 4-1 mixer with this.
/Stefan
Niio1
