TH-201 "Mankato" PCBs available
Page 3 of 7 [156 Posts]
etaoin
PostPosted: Thu Aug 09, 2007 6:45 am    Post subject: Re: TH-201 "Mankato" PCBs available
Subject description: Polystyrene caps
Next best choice would probably be polyester, and then mylar or other "film" caps. Worst would be ceramic.
Shouldn't polypropylene be somewhere between polystyrene and polyester as well? I've seen those recommended as par to polystyrene for VCO timing caps. I have one in both my CGS VCO and ASM 'ultra' VCO. Ray Wilson uses silver mica in his VCO.
And why do I have so many different VCOs?
http://www.casia.org/modular/
Tim Servo
PostPosted: Thu Aug 09, 2007 3:18 pm    Post subject: Re: TH-201 "Mankato" PCBs available
Yup, forgot about polypropelene. Those are almost as good as polystyrene, and for a VCF they should be just fine. Silver Mica is also good, although they tend to be expensive from what I recall. Remember that a VCO only needs one timing cap, while the Mankato (and other 4-pole filters) need four timing caps.
You have so many VCOs because they're cool and they make noise! However, I'll provide my address if you feel you have too many. Wink
Tim (can you ever have too many VCOs?) Servo
davebr
PostPosted: Thu Aug 09, 2007 10:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I bought SMT 1K tempco's a Digikey and mounted two directly on the SSM2164. Details at
http://modularsynthesis.com/magicsmoke/mse.htm
ENDIF wrote:
My magnificent blue slab arrived a few days ago, and I'm currently knee deep in building it, just gotta find me a 2k tempco.. pesky things.
softfin
PostPosted: Fri Aug 10, 2007 4:20 am    Post subject: SSM2164s Reply with quote  Mark this post and the followings unread
I'm about to start populating two Mankato boards, but noticed that my stock of SSM2164 chips is running low...only 1 left.
So, if anyone knows a good source (preferably in Europe) where to get these for a decent price, please drop a message Smile
etaoin
PostPosted: Fri Aug 10, 2007 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Is using two 1k tempcos where a 2k tempco is specified possible in general? I have plenty of 1k tempco's, but no 2k tempco's left.
Usine Karate
PostPosted: Fri Aug 10, 2007 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just received boards, they look really good, thanks!
Was just wondering if it would be possible to power the Mankato from a 12v supply? And if so what, if any, modifications would be necessary, I noticed that Bugbrand (if you're out there) was running his from 12v, any ideas on modifications?
Ta!
davebr
PostPosted: Fri Aug 10, 2007 8:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just finished my Mankato module. Wow, what a lot of range. I'll have to decide whether to leave it or perhaps trim it down a bit. I used a Stooge bracket for the PCB, Loffink chiclets for the potentiometers, FPE panel, and Vishay 149/248 potentiometers. You can just see the SMT tempcos on the SSM2164. What a neat design. Now to go play ...
Scott Stites
Audio files: 96
PostPosted: Sat Aug 11, 2007 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Thomas Henry,
If you are out there........
I'm also a 19" rack panel head. Have you designed a 19" rack panel for the Mankato filter? I'd be curious to see your design as I imagine others on the forum would. Gotta milk as much input before you're back to class!
Hey Antman,
Thomas is out there - really out there, in fact. He's in Kansas on vacation, and I expect him to drop by here in an hour or two. I've met with him the last couple of nights, and it's been a really enjoyable experience. I'll ask him about the panel design - I bet he's got one.
There should be time for that before the townspeople get him properly tarred, feathered, and mounted on the rail Laughing
Take care,
Scott
My Site
PostPosted: Sat Aug 11, 2007 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, i think so, and using 3300ppm would be even better that 3500 FWIK.
Evan
PostPosted: Sun Aug 12, 2007 12:05 am    Post subject: Reply with quote  Mark this post and the followings unread
So, in general, the lower the ppm value, the better?
There are some 3000ppms (I think) available locally.
sneakthief
PostPosted: Sun Aug 12, 2007 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
the theoretical ideal for a thermistor in a VCO is 3300ppm.
Sneak-Thief - raw electrofunk
Thomas Henry
PostPosted: Wed Aug 15, 2007 8:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello Antman,
I did do a panel three years ago for the prototype. I searched my decrepit computer, but only found a corrupted file for it. So I guess the answer is "no." Sorry.
Say, when I was traveling the byways of Kansas last week it occurred to me that we crossed paths a decade ago. I finally placed the name with the project. You were working on a standalone Soundblaster unit for MIDI use. I remember I was absolutely swamped keeping MAP afloat and wasn't able to follow up on your ideas. Anyway, is that still a good project, or has time evaporated the surplus market for what you were doing? It sounds really neat.
Thomas Henry
Tim Servo
PostPosted: Wed Aug 15, 2007 9:43 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: 12V Mankato
Ta!
Hey There,
Yes, you can run a Mankato on ±12V. The output levels will be lower (when oscillating, the sines will probably be closer to ±4V than ±5V), but that will be the most noticeable effect. Also, I would definitely not use PT1 and PT2 on a 12V system (replace them with jumpers or ferrites). They'll drop the supply rails to the chip too low. I think the V/Oct trim will still have enough range, so you're okay there. Of course, as with any system, you don't want to accidentally run a 15V signal into it because that could potentially damage the op amps.
Hope this helps!
Tim (Mankato wrangler) Servo
vtl5c3
PostPosted: Thu Aug 16, 2007 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tim,
Have you replenished your board stock for the Mankato filter?
R.
Tim Servo
PostPosted: Thu Aug 16, 2007 2:11 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: Board stock
vtl5c3 wrote:
Hi Tim,
R.
Accoording to Fed Ex tracking, they should be here Friday / Monday. This incoming batch is half sold out, so that leaves us about 25 boards. If you've already placed an order, then you're all set. Hopefully I will still have a few to sell at AH Cali in a few weeks!
Tim (not bored of boards) Servo
Usine Karate
PostPosted: Thu Aug 16, 2007 3:56 pm    Post subject: Re: TH-201 "Mankato" PCBs available
Thanks for the info Tim. That works out well for me cos I have no idea what these are! I'll stick some ferrites in and see how she blows.
Tim Servo
PostPosted: Thu Aug 16, 2007 6:04 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: 2K tempcos available
By the way,
Magic Smoke has ordered a whole big buncha 2K tempcos and they'll be here next week!
They are 2K 1/4W 2% 3500ppm... in case you were wondering Wink
The prices are:
1 $3.50 +shipping (see below)
2 to 5 $3.00ea +shipping
5 or more $2.75ea +shipping
Shipping for any quantity up to 10 pieces is $1.50US/Canada, $2.50 EU/UK/Australia. If you order up to 10 pieces with a Mankato PCB, then the shipping will the same as the board alone. If you need more than 10 pieces, drop us a line and we'll figure it out. As always, we take PayPal to magsmoke@gmail.com. Thanks for the bandwidth, now get back to soldering!
Tim (or get back to breadboarding) Servo
Coriolis
PostPosted: Mon Aug 20, 2007 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Now THAT is a good deal!
Can you add some to my pcb order (assuming you haven't sent the boards to day)?
C
3vcos
PostPosted: Mon Aug 20, 2007 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like the BOM for the filter is gone and its not on the website. I'd like to have a look before I buy a Mankato. Any chance of reposting it?
Tim Servo
PostPosted: Mon Aug 20, 2007 11:42 am    Post subject: TH-201 "Mankato" PCBs available
Subject description: 2K Tempcos
C
Absolutely! Just got the new batch of boards, so they'll start shipping in the next few days. Just PayPal us for how many Rs you want (cost of the Rs only, the shipping is no extra cost when included with a board order).
And thanks!
And VERY GLAD E-M IS BACK UP!
Tim (just a happy kind of guy) Servo
Tim Servo
PostPosted: Mon Aug 20, 2007 12:02 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: TH-201 Rev03 BOM
No problemo. Here is the Parts List for Rev03 Mankato boards. Let me know if you have any questions.
Tim (da BOM) Servo
(edited 21-August for suggested value of C15)
TH-201-03-Parts List.pdf
Mankato Rev03 Parts List 21-August-2007
 Filename:  TH-201-03-Parts List.pdf
 Filesize:  592.95 KB
 Downloaded:  404 Time(s)
PostPosted: Tue Aug 21, 2007 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
i am populating the PCB tonight and stumbled over C15. the BOM states three values for that cap: 10pf, 15pf or even 22pf. what is that about? should i stay with the 10pf as for the other caps?
Tim Servo
PostPosted: Tue Aug 21, 2007 11:20 am    Post subject: TH-201 "Mankato" PCBs available
Subject description: C15 value
My bad! That SHOULD say "optional, can use 10pF." Thomas' original design had a 22pF in that position, but I haven't noticed any difference with a 10pF in there. This allows you to buy one less part value. I'll fix that and repost the BOM. Thanks!
Tim (fixin' the BOM, Boss!) Servo
PostPosted: Wed Aug 22, 2007 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for your quick reply, tim.
next question: if i'd decided to use only 4 outputs of the mankato, which one would you recommend from a personal point of view? maybe somebody already mentioned this but i probably missed it.
Tim Servo
PostPosted: Wed Aug 22, 2007 1:03 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: Pick 4 outputs
Well, my original ProtoMankato (Mankatus Tweakus Originalus) features the 12, -12, 24 and -24 outs. Great sound, and I get quadrature sines if I need them. The outputs are like this:
-12dB = 0°
-24dB = 90°
12dB = 180°
24dB = 270°
If you really want a more "electronic" sound you could also chose to use the 6dB and 18dB outputs instead:
6dB = 0°
18dB = 90°
-6dB = 180°
-18dB = 270°
Personally, I'd go with the first option. Of course, if you don't care about using the quadrature sine wave outs, then just pick the 6, 12, 18 and 24 outs. You can still use the Mankato as a VCLFO, but the phases would be:
6dB = 0°
12dB = 225°
18dB = 90°
24dB = 315°
With this setup, you could use external inverters with the 0 and 90 degree outs to get quadrature sines if you really needed them. Might be a pretty attractive option in a modular.
So the final answer is - it depends on how you're going to use the Mankato. Smile
Tim (working all the angles) Servo
