  bingsatellites Mostly Ambient
Looping with Nord Lead 2x
Page 1 of 1 [4 Posts]
bartbart
PostPosted: Fri Jul 27, 2007 10:44 am    Post subject: Looping with Nord Lead 2x Reply with quote  Mark this post and the followings unread
I just got mine on monday and the manual is no help. I want something to play automatically while I play something manually.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Jul 27, 2007 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome bartbart
Use the KeyBoard Split function [Manual page 14] One part will be the playing keyboard, the other will be used for looping.
Set the looping patch in arpeggio mode, press Shift+Hold and play a chord on the keyboard, which starts the arpeggio. If you want the arpeggio change timbre like, use a Morph set to the wheel and don't use any Morph to the playing Patch.
Wout
bartbart
PostPosted: Sat Jul 28, 2007 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, that helps a little, but that's not exactly what I was looking for. That only repeats like the last 2 notes played and not the way I played them.
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Sat Jul 28, 2007 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are looking for a built in sequencer like on the 'workstation' type keyboards. I am pretty sure you won't find one on a Nord Lead. You should be able to play loops from an external sequencer though.
