Brushed Aluminum
Page 1 of 1 [16 Posts]
abis
PostPosted: Fri Aug 24, 2007 8:18 am    Post subject: Brushed Aluminum Reply with quote  Mark this post and the followings unread
I just made my first attempt at brushing aluminum and it went quite well, I must say. I was wondering if anyone could recommend a product I could use to seal the aluminum. I plan on printing up a decal as per Thomas Henry's Nuts and Volts article. (the link for that appears to have been lost btw.)
Here is the link to the tutorial I followed for the brushed aluminum:
http://forums.bit-tech.net/showthread.php?t=114028
Andrew
Photon
PostPosted: Fri Aug 24, 2007 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
This is the stuff:
http://www.permalac.com/
I've been using it on my brass panels to keep them from oxidizing and it works great. I use the matte finish. expensive but was worth it for me.
Freq Out
o---------------<>---------------o
flickr
goldenechos
PostPosted: Sun Aug 26, 2007 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I have been brushing aluminum and I have not found anything that works well to prevent oxidizing... I have tried clear laquer as well as a spray on clear POLY both in matte finishes. The metal looked AWESOME that day, but has since small patches of what I presume to be oxidization. These were small freckles of discoloration...
So I put the POLY on thicker and I am getting almmost no oxidization BUT, the look of the metal is not as pleasing... the thick coat of POLY obscures much of the brushing and gives the metal a more grey, plain look.
Permalac looks promising, and yes it is about 3 tmies the cost, but if it works, it will be worth it!
Please share if you have other success.
TR
Photon
PostPosted: Sun Aug 26, 2007 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a side by side photo. The plate on the left was an early etching test that I did and has been oxidizing for a few months now. On the right is a more recent panel that has been treated with the permalac spray. Its looked the same since I sprayed it about a month ago. The mottled color in the lower corner & other imperfections occurred during etching from pinholes in the mask.
The photo is not so good but hopefully the idea comes across.
sorry if this comes across like a late night tv ad...but WAIT, there's more!
P.
How much would you pay to keep your synth panels from oxidizing? $100? $200? Now for just three easy payments of $5.98...
 Filesize:  256.25 KB
 Viewed:  288 Time(s)
Freq Out
flickr
goldenechos
PostPosted: Sun Aug 26, 2007 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
UPDATE. Just had a chat with my Dad about this... he works on hot rods and custom cars. He shot down the spray on POLY as he said that it WILL YELLOW with age. This could be desirable to some, but if you are trying to preserve a look, it will obviously not be good.
He sugested a clear laquer... appparently I was using clear enamel, which, he said, will not do a very good job at preventing oxidization.
BTW...
Photon your work is beautiful. It has this steampunk vibe that is too often missing from modular panels.
TR
Photon
PostPosted: Sun Aug 26, 2007 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, Permalac is a laquer. I'm pretty sure thats what the 'lac' part refers to Very Happy
Freq Out
flickr
Clack
PostPosted: Mon Aug 27, 2007 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
Do you think the 'clear laquer' spray paint you can get in car shops would work?
sorry to budge in, maybe off topic, but is it possible to etch aluminum with ferric chloride? I have some of that laying around with some press'n'peel
Clacktronics.co.uk
PostPosted: Mon Aug 27, 2007 4:31 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.finishing.com/205/56.shtml suggests it is.
Photon
PostPosted: Mon Aug 27, 2007 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I imagine it would. I probably would have tried it if I hadn't stumbled across the other first.
It's worth a try. You may need a stronger concentration than is sold for PCB etching. I guess experimentation is key here.
goldenechos
PostPosted: Mon Aug 27, 2007 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Check out Galv-etch as well if you are into etching Aluminum.
I have been wanting to try this as it is an enviromentally sane method of etching metal.
Works on Brass as well Photon.
TR
markusw
PostPosted: Thu Aug 30, 2007 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
This one was done with photo resist and exposure through an ink jet transparency. Developing was done with 1% NaOH, etching with ferric chloride (slightly lower concentration than I use for PCB's).
Finally, I put on a clear coat of "Zapon" laquer. Zapon laquers, as far as I know, are nitro cellulose-based. They are supposed not to get yellow over time.
So far this seems to be true. Wink
Regards,
Markus
Photon
PostPosted: Thu Aug 30, 2007 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Markus
Great job! Absolutely magnificent!
Dan Lavin
Audio files: 21
PostPosted: Thu Aug 30, 2007 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Markus,
That is freakin' amazing! Shocked
markusw
PostPosted: Thu Aug 30, 2007 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad you like it Very Happy
The only drawback: you really need some good ventilation because that photoresist doesn't smell very healthy. Ideally, you also should have some kind of stove to dry the photo resist at IIRC 60°C for about 15 min.
The photo resist btw is them same type used for PCB's.
For exposure (like for my PCB's) I used a standard 250W bulb. It takes about 10 min to develop, but since I don't do enclosures on a large scale this isn't a problem.
Developing and etching is pretty straightforward.
Unkie Al
PostPosted: Wed Nov 07, 2007 8:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone attempted an engine turned finish? Think 1950s sports car dashboard, or the Spirit of St Louis engine cowling: http://www.charleslindbergh.com/history/sec/22spiritcowling-post1970.jpg
goldenechos
PostPosted: Thu Nov 08, 2007 5:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I did something like an engine turn finish using a dremmel. I did not like it though... too distracting to look at, and the printing on the panel was hard to read.
Tony
