how to set lower octaves
Page 1 of 1 [2 Posts]
amnesia
PostPosted: Sat Sep 01, 2007 4:52 pm    Post subject: how to set lower octaves Reply with quote  Mark this post and the followings unread
Hi all
again a new A6 user and I have this question.
I understand what the transpose button does.....but want to know if I make a sound and later realise that i would like to access 2 octaves down, how can I do this easily without having to readjust OSC1 and 2 or press the transpose button so it transposes every other sound?
Can the octave button be set individually for each program?
kraster
PostPosted: Mon Sep 03, 2007 7:47 pm    Post subject: Re: how to set lower octaves Reply with quote  Mark this post and the followings unread
amnesia wrote:
Hi all
Simplest way to do this is to duplicate of the program with the OSCs tuned 2 octaves down and save it with a "-2" on the end of the filename.
You could also use the same program assigned to different parts in MIX mode and adjust the octaves on each part within the Mix mode. You can then use the lower buttons to cycle through your various octaves.
I personally don't see the problem using the transpose button. Hit the transpose button and hold the lower C and you have a -2 octave transpose.
Niio1
