Chuck, Reactivision & OSC
Page 1 of 1 [4 Posts]
emoc
PostPosted: Fri Sep 07, 2007 3:44 pm    Post subject: Chuck, Reactivision & OSC
Subject description: an attempt to use the reactable software
I'm trying to implement the reactivision TUIO/OSC receiver for ChucK.
Reactivision is the open-source software behind reactable. It runs a communication protocol based on OSC called TUIO (tangible user interface..., ). A "Tuio simulator" (java applet) helps debugging. This simulator is already a nice interface : each object can be rotated & moved and physics data are transmited through TUIO / OSC
reactable : http://mtg.upf.edu/reactable/
TUIO http://modin.yuri.at/publications/tuio_gw2005.pdf
TUIO simulator http://mtg.upf.edu/reactable/?software
To fully implement, the receiver must catch three different message : alive, set, and fseq. 'set' and 'fseq' are predefined formats but alive changes with how much objects are on the table. 'set' messages are the most important because they carry physics data (motion, position) and you can already have fun with it! (and the script below)
Code:
/tuio/[profileName] set sessionID [parameterList]
/tuio/[profileName] alive [list of active sessionIDs]
/tuio/[profileName] fseq int32
The script chuck below catch 'set' & 'fseq' messages, but to catch 'alive' messages, you'll need flexible pattern matching, if there's any way to do it with ChucK ???
A dirty hack & code nightmare could be to add as much osc receivers as objects on the table each trying to catch one more integer...
Code:
// 7 sept. 2007 / chuck 1.2.1.0 /
// nom de l'hote et port par défaut
"localhost" => string hostName;
3333 => int receiverPort;
<<< "port de reception pour les messages OSC:", receiverPort >>>;
// objet OSC pour la réception
OscRecv receiver;
receiverPort => receiver.port;
// commencer l'écoute sur le port
receiver.listen();
// créer une adresse réceptrice des messages, y stocker la valeur de fréquence reçue
receiver.event( "/tuio/2Dobj,s,i,i,f,f,f,f,f,f,f,f" ) @=> OscEvent oeset;
receiver.event( "/tuio/2Dobj,s,i" ) @=> OscEvent oe1;
string a_type; int a_sessionid; int a_fiducialid; float a_xcoord; float a_ycoord;
float a_angle; float a_xmov; float a_ymov; float a_rotation;
float a_movaccel; float a_rotaccel; int frame_id; int nb;
fun void oesetListener() {
  while ( true ) {
    oeset => now;                    // en attente de l'arrivée d'un message OSC
    // capturer le nouveau message
    while ( oeset.nextMsg() != 0 ) {
      oeset.getString() => a_type;        // = set                        string
      oeset.getInt()    => a_sessionid;  // session ID, temporary ID,    int32
      oeset.getInt()    => a_fiducialid; // fiducial ID number,          int32
      oeset.getFloat()  => a_xcoord;     // position, range 0..1,        float32
      oeset.getFloat()  => a_ycoord;     // position, range 0..1,        float32
      oeset.getFloat()  => a_angle;      // angle, range 0..2PI,         float32
      oeset.getFloat()  => a_xmov;       // movement vector,             float32
      oeset.getFloat()  => a_ymov;       // movement vector,             float32
      oeset.getFloat()  => a_rotation;   // roration vector,             float32
      oeset.getFloat()  => a_movaccel;   // motion acceleration,         float32
      oeset.getFloat()  => a_rotaccel;   // rotation acceleration,       float32
      <<<"set : ", a_sessionid, a_fiducialid, a_xcoord, a_ycoord,
          a_angle, a_xmov, a_ymov, a_rotation, a_movaccel, a_rotaccel>>>;
spork ~ oesetListener();
fun void oe1Listener() {
  while ( true ) {
    oe1 => now;                  // en attente de l'arrivée d'un message OSC
    while ( oe1.nextMsg() != 0 ) {    // capturer le nouveau message
        oe1.getString() => a_type;        // = fseq || alive              string
      oe1.getInt()    => nb;             // frame ID || object sessionID,int32
      <<<a_type, " : ", nb>>>;
spork ~ oe1Listener();
while (true) {
  0.5::second => now;
codelab.fr
PostPosted: Fri Sep 07, 2007 7:36 pm    Post subject: Re: Chuck, Reactivision & OSC
Hmmm, A good first step might be one OSC receiver that would parse OSC, then send ChucK events for the different shreds? That would at least save the OSC receivers. I'm not sure wether you can make a array of events but that would be a possible solution.... You could just make a array of those that's longer then the amount of blocks that you have and asign one to each shred as you start it. I don't think unused events have any real overhead that matters.
Disclaimer; it's 4:30 here and I haven't thought this through.
emoc
PostPosted: Tue Sep 11, 2007 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Kassen for your answer,
I don't know how to do this global receiver. So, I'll make as many OSC receivers as necessary to update a big array containing parameters from reactivision markers. Other shreds will get data there to do what they have to do!
codelab.fr
emoc
PostPosted: Thu Apr 22, 2010 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
It's a rather old thread, but for those interested, there's a TUIO class for chuck by Vilson Vieira : http://vilson.void.cc/wiki/forums.html?n=Main.ChuckTUIO
codelab.fr
