<on air> Faux Pas Quartet and friends Music From Last Thursday [rebroadcast]
Schulte Compact A Phasing
Page 9 of 26 [649 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10, 11, ..., 24, 25, 26 Next
jhaible
PostPosted: Mon Feb 04, 2008 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mr Clack wrote:
whats the smallest transformer I can use? I mean what region of current will this need?
Less than 200mA.
Would there be any point in heatsinking the regulators to the case? I understand you cant electronically contact a regulator to chassis ground i will insulate that - pointless maybe
Yes, if you use insulation between the transistors / regulators and the heatsink, you can fix the heatsinks to the (grounded !!) chassis.
It's the better solution thermally, anyway. But you have to keep wires short to prevent oscillation.
6.5v 300mA 0.97W
One of these numbers must be wrong.
JH.
Clack
PostPosted: Mon Feb 04, 2008 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
[quote="jhaible"]
Mr Clack wrote:
6.5v 300mA 0.97W
JH.
hmm yes - I meant to post this one
6.5V 150mA 0.6W 70
from Here
sorry for the fuss - ill just buy them from the dutch place see what happens
thanks for the info it was helpfull Very Happy
Clacktronics.co.uk
softfin
PostPosted: Thu Feb 07, 2008 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks JH! I received my boards today. I didn't get any LDRs, though. I suppose they will be shipped separately later...?
jhaible
PostPosted: Thu Feb 07, 2008 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you looked between the two boards? The LDRs should be sandwiched there ...
If you don't have them - can you tell me under what name you have ordered? (I've sold a few boards without LDRs after the LDR-order-deadline, too - just making sure you're not among these.)
JH.
softfin
PostPosted: Fri Feb 08, 2008 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed Now I have. All LDRs are included like they should!
b-funk
PostPosted: Mon Feb 11, 2008 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
i populated my first board, and besides i have the wrong relays, it´s working. it´s working GREAT!!!
cool stuff, really...
i´ll post some pics tomorrow...
best wishes,
tobias
Luka
PostPosted: Mon Feb 11, 2008 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
boards arrived in australia
thanks jurgen
problemchild
melbourne australia
morbank
PostPosted: Mon Feb 11, 2008 10:51 pm    Post subject: Capacitors? Reply with quote  Mark this post and the followings unread
Hello All, sounds like some of you are already playing with your phasers! As for me i've nearly got all the components, but I can't find the right sizes for some of the capacitors. If anyone can point me towards finding the following (preferably on Mouser), I'd greatly appreciate it!
1 x 33pF Ceramic (2.5mm spacing)
1 x 680pF Ceramic (2.5mm spacing)
1 x 1nF Ceramic (2.5mm spacing)
8 x 33nF (Cx) (5mm or 7.5mm spacing)
1 x 100nF (u1) (5mm)
1 x 220nF (u22) (5mm or 7.5mm spacing)
1 x 220nF (u22) (5mm spacing)
1 x 1uF (5mm or 7.5mm or 10mm spacing)
Also, any tips for what transformer to get and where to connect it would help too.
Thanks, Clay
jhaible
PostPosted: Mon Feb 11, 2008 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
best wishes,
tobias
Congratulations!
For what I know, you're the first one who has finished it!
JH.
b-funk
PostPosted: Tue Feb 12, 2008 2:45 am    Post subject: Reply with quote  Mark this post and the followings unread
so, did i win the price?
what is it? what is it?
Etaoin
PostPosted: Tue Feb 12, 2008 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Mine's finished as well.
I also needed to hardwire the relay points as my relay didn't work either (Futurlec HFD2-12). The LED switches on and off, but the relay doesn't. I think I have another DIP one somewhere so I'll try that.
 Filesize:  104.97 KB
 Viewed:  3667 Time(s)
http://www.casia.org/modular/
Etaoin
PostPosted: Tue Feb 12, 2008 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I haven't adsjusted any trimmers yet, so I'm not sure mine sounds like it is supposed to sound, but I did an mp3 anyway:
http://www.casia.org/modular/mp3/schultephaser.mp3
Getting this feedback is pretty tricky. There's little room between resonance and oscillation.
Etaoin
PostPosted: Tue Feb 12, 2008 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I can now confirm that it was indeed the relay. I also have an old Takamisawa RY12W and that works fine.
Not sure why the Futurlec one won't work. The coil measures around 700 ohms so it's not dead (at least not the coil). It came brand new from Taiwan anyway.
Etaoin
PostPosted: Tue Feb 12, 2008 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
BTW, I replaced the mp3 above as I found that actually connecting the third lamp makes quite a difference to the sound Very Happy
b-funk
PostPosted: Tue Feb 12, 2008 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
pix... ok, etaoin, you beat me with that... nice work btw...
tomorrow i´ll try another relay, hope it works.
best wishes,
tobias.
it blinks!!!
 Filesize:  58.02 KB
 Viewed:  3605 Time(s)
the brothers...
 Filesize:  51.67 KB
jhaible
PostPosted: Tue Feb 12, 2008 4:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Strange about these relays.
If you hook it up directly to 15V, with a 100 Ohm resistor in series, does it work then?
Is your BD239 that drives the relay a C type? (Beta high enough?)
JH.
b-funk
PostPosted: Tue Feb 12, 2008 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
jürgen,
yes, i use a c type...
i´ll try your suggestion to hook it up to 15 volts if the new relay fails, too...
strange thing that also etaoin had similar problems...
best wishes,
tobias.
Etaoin
PostPosted: Wed Feb 13, 2008 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
My BD239 is also a C-type.
By the way, is the relay supposed to get slightly warm?
Etaoin
PostPosted: Wed Feb 13, 2008 12:58 am    Post subject: Reply with quote  Mark this post and the followings unread
The Futurlec relay is fine connected straight to 15V (with the 100 ohm resistor).
jhaible
PostPosted: Wed Feb 13, 2008 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
All right. Then probably the transistor's beta is too small.
Try a smaller value for R77 (see http://www.jhaible.heim.at/compact_clone/jh_krautrock_phaser_refdes.pdf)
Formerly 10k - try 4.7k .
If this doesn't help, I probably have to specify a different transistor type.
Oh, and befor you do anything else:
With the Relay soldered in, try shorting D15 momentarily with a piece of wire (bypassing the transistor), and see if the relay works correctly.
Sorry for having to go thru these procedures. I knew the BD239C is a bit on the low side of beta (even the C type), but I wanted to keep component variation low.
If your relay doesn't need more than 100mA, you could even use a small signal transistor like the BC550C (but watch the different pinout:
BD239 is B-C-E. BC550C is C-B-E. All seen srom the side where the numbers are printed on the plastic.)
JH.
Etaoin
PostPosted: Wed Feb 13, 2008 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Found it. The Futurlec relay has a reversed polarity coil. It needs + at pin 1. It won't switch the other way round. The Takamisawa one I have is non-polar.
jhaible
PostPosted: Wed Feb 13, 2008 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I see. They probably have a free-wheel diode inside, too, which may explain things getting warm.
Haven't thought about polarized relays, otherwise I'd have reversed the two connections.
JH.
Etaoin
PostPosted: Wed Feb 13, 2008 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
It's the non-polarized one that gets warm. I haven't been able to use the polarized one Wink
jhaible
PostPosted: Wed Feb 13, 2008 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
But the non-polarized works?
JH.
Etaoin
PostPosted: Wed Feb 13, 2008 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that's fine otherwise.
AmbiphonicDSP
