Travis Coats
Posted: Sun Sep 09, 2007 6:40 pm Post subject:
Places no one should ever see Subject description: Eccentric Ambient Piece |
This is a very eccentric composition. Tell me what you away with in mind after listening.
Listen _________________ Check out my latest projects here:
http://www.allinnia.com
http://www.allinnia.com/Wordpress |
Joined: Jan 31, 2003 Posts: 18195 Location: Durham, NC
Audio files: 211
Posted: Sun Sep 09, 2007 7:01 pm Post subject:
Very nice sounds - the beginning is spectacular
When the 4/4 conventional drum came in (and the base) you lost me. Just my opinion, of course. _________________ --Howard
my music and other stuff |
Travis Coats
Posted: Sun Sep 09, 2007 7:18 pm Post subject:
Thanks Mosc, it was meant to be a very "theme-based" song. I think that middl part you are talking about will need better mixing, I feel the 4/4 signature of those drums is a little too much, too fast now that you point it out. I am glad you liked it, I didn't expect it to be commented on so soon. _________________ Check out my latest projects here:
Audio files: 211
Posted: Sun Sep 09, 2007 7:25 pm Post subject:
It's a good one that could easily be a great one. That chanting should is very arresting and evocative. The mix with the other sounds is very dramatic and interesting. Even the piano seems to fit, but the drums just seemed out of place.
But consider that I'm an old timer. _________________ --Howard
Joined: Apr 03, 2004 Posts: 24075 Location: The Netherlands, Enschede
Audio files: 277
Posted: Mon Sep 10, 2007 12:02 pm Post subject:
I think this is beautiful, the drums coming in for me create a sort of a contrast between an inner and an outer world. _________________ Jan
Audio files: 211
Posted: Tue Sep 11, 2007 10:03 am Post subject:
Must be because you are so young.
Seriously, this is why one must take criticism (even constructive) with a bit of salt. Everyone responds differently, and differently at different times. _________________ --Howard
Mohoyoho
Travis Coats
Posted: Tue Sep 11, 2007 3:53 pm Post subject:
Thanks for all the comments. This one was very experimental and I was antsy to hear what people thought about it.
Mosc: Constructive or Deconstructive criticism, I respond well to either and I like to hear what people say about or take away. I believe what you said about the transition is partially true. Nothing that can't be fixed by some better mixing on my part...maybe a better fade and good lead in.
Sometimes it is hard to mix good solid beats with more soft, pad-like instruments and acoustic one like the piano. I love the combination though so I will keep going until I get it right.
Thanks again. _________________ Check out my latest projects here:
Johan Zwart
Joined: Mar 26, 2004 Posts: 496 Location: Utrecht, Netherlands
Audio files: 19
