8038 VCO PCB layout for press'n'peel blue
Page 2 of 3 [58 Posts]
janvanvolt
PostPosted: Sat Oct 06, 2007 5:46 pm    Post subject: Re: 8038 VCO PCB layout for press'n'peel blue
Subject description: any interest?
The current version does work with an 8038 ? I am a bit puzzled as you speak about various chips for the core ...
(and no, i have not yet received my copy of the vco cookbook)
PostPosted: Sun Oct 07, 2007 8:44 am    Post subject: Re: 8038 VCO PCB layout for press'n'peel blue
hi jan,
could you be a little more precise, please? or do you refer to another post/topic?
apologize me for being dense here... Embarassed
fonitronik at
PostPosted: Thu Oct 11, 2007 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
i'd recommended to STOP this project for a time. according to thomas' valuable comments concerning the cross-talk i will redesign the PCB layout hopefully next week.
see here:
http://electro-music.com/forum/topic-20737.html
fonitronik at
PostPosted: Mon Oct 29, 2007 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
i just finished a new layout. the two oscillators now only share the THAT IC which is a passive device anyway. the other parts of the oscillators are isolated from each other.
it is reviewed and triple checked (PCB against schematic) but i did not build it yet. so it's on your own risk!
www.modular.fonik.de/pdf/TH_dual8038VCOv2.pdf
 Filesize:  552.02 KB
 Viewed:  244 Time(s)
fonitronik at
softfin
PostPosted: Mon Oct 29, 2007 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Fonik! I'm going to etch a pile of different boards probably some time next month and I'm planning to etch this one as well. I'll let you know how it turns out.
PostPosted: Mon Oct 29, 2007 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
you're the man, softfin. that's great.
fonitronik at
Etaoin
PostPosted: Wed Oct 31, 2007 1:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Fonik!
Where did you get the THAT320? I can't seem to find that anywhere.
http://www.casia.org/modular/
PostPosted: Wed Oct 31, 2007 1:16 am    Post subject: Reply with quote  Mark this post and the followings unread
there was a groupbuy on the german forum, got just two from a member.
take a look here:
http://www.ka-electronics.com/that300/that300.htm
or
http://www.cedos.com/transistor_arrays.htm
fonitronik at
softfin
PostPosted: Mon Nov 12, 2007 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Almost finished this 8038 project! I didn't have any THAT chips so I had to improvise. Laughing
 Filesize:  670.7 KB
 Viewed:  201 Time(s)
PostPosted: Mon Nov 12, 2007 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
sweet, looks pretty exceptional! hope it all works out all well... you are the prototyper for the new layout...
fonitronik at
softfin
PostPosted: Wed Nov 14, 2007 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Finished!
The Coarse Tune controls seem to interact somehow with each other... But not on all settings. Any guesses what could be the reason for this ?
Btw, I really like the character of the sine wave produced by this VCO, it's very soft, perhaps somewhat "wooden" sounding.
 Filesize:  268.38 KB
 Viewed:  194 Time(s)
PostPosted: Wed Nov 14, 2007 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
softfin wrote:
Finished!
so the layout finally works? good to know! thank you so much, L.
concerning the interaction: the layout is actually divided in two layouts, one for each VCO, they even have their own power bus decoupling caps... sorry, no idea. wait! the ground network is not devided that strictly: especially the transistors share one ground node. don't know if that could cause a problem...
indeed. did not look on the scope yet, though.
fonitronik at
softfin
PostPosted: Thu Nov 15, 2007 12:01 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, ground remains shared between the two circuits, but I cut the connections for +-15 between the two VCOs and provided the +-15V separately to both sides.
Works fine now!
PostPosted: Thu Nov 15, 2007 12:12 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, i got it. the layout provides just shared filters for the power rails (R1/R2). i will have to change this!
glad you solved it.
fonitronik at
Luka
PostPosted: Tue Feb 05, 2008 8:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
im looking for some top notch sine vcos
would this fit the bill?
can you gents post some examples pls
problemchild
melbourne australia
numbernone
PostPosted: Thu Feb 07, 2008 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I have been poking at a layout for the 8038 myself, and may have to become the second tester for your design FONIK.
What level of Sine trimming is implemented on this layout?
And for my obvious and or dumb question...The layout currently on your site is the revised version??
Thanks
PostPosted: Thu Feb 07, 2008 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
none!
yes
i will hopefully do some scope screen shots on the weekend.
fonitronik at
numbernone
PostPosted: Thu Feb 07, 2008 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow glad to hear you can get a decent sine without any of the add on circuitry, damn glad!!!
Great work Fonik! I think this will be the foundation of my 10,000 oscillator ANS meets Raymond Scott monstrosity (OK maybe 6).
numbernone
PostPosted: Sat Feb 16, 2008 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did a quick test run on my new 8038VCO this morning, needs a couple lil kludges, but it seems like it will be very healthy!
I fit a pair on a tiny little ExpressPCB mini board, with separate power sections and grounding. it is definitely a crowded party, no room for parts to be lying down.
 Filesize:  45.71 KB
 Viewed:  162 Time(s)
softfin
PostPosted: Mon Feb 25, 2008 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I finally put the dual 8038 vco in my modular.
It had been gathering dust for months because of lack of space in the modular, but now that I've got power in my 3rd cabinet, it was time to tune this vco, put it in the cabinet and test it further.
For some reason, I find it quite hard to tune it. After several hours of adjustments, I was able to achieve only about 4 octaves tracking.
In comparison, it took 10 minutes to get clean 6 octaves with a xr2206 osc.
Would appreciate any suggestions how to improve the tracking Smile
 Filesize:  33.65 KB
 Viewed:  13290 Time(s)
 Filesize:  33.08 KB
 Filesize:  29.6 KB
janvanvolt
PostPosted: Thu Apr 09, 2009 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
My module is also working so far. See waveforms on my flickr! page...
Flickr: http://www.flickr.com/photos/jczmok/sets/72157616434119843/
But ... I experience the TL's are getting quite hot, but not the 8038's ..
Wonder if somebody has an idea. Module is powered by +/- 15V
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
PostPosted: Thu Apr 16, 2009 10:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
i just wanted to let you guys know: the problem has been solved (some communication via email) and it is working fine now.
unit-sound was able to get 6 usable octaves from it - after 10min tuning using a tellun.com tuner!
i think i will throw away my module built from PCB version1 and rebuild it with the v2 board...
fonitronik at
janvanvolt
PostPosted: Fri Apr 17, 2009 2:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Sidenote: Make sure you use TL071/TL081 for U8/U9. I mistaken TL072 and all the TL's got very hot then. So if you experience this error, try to check the TL's first.
As fonik outlined: It's working perfect now. I used a .COM VCO and a octave switch to tune both OSCs.
kupfer_m
PostPosted: Thu Dec 02, 2010 8:02 am    Post subject: Where's the cookbook? Reply with quote  Mark this post and the followings unread
I have some 8038 chips laying around here and I'd like to build this VCO but I can't find the VCO cookbook nor a schematic of this design.
Any help appreciated!!
thanks!
Tim Servo
PostPosted: Thu Dec 02, 2010 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Kupfer,
I'm working to get the VCO Chip Cookbook available for sale. It's a big chore, as I'm preparing a PDF from paper originals. Lots of scanning and cleaning.
I hope to have this available soon, but in the meanwhile I think some of the PCB layouts should be available. Right?
Tim (even have my wife helping scan stuff) Servo
mps board
