cappy2112
Joined: Dec 24, 2004 Posts: 2088 Location: San Jose, California
Posted: Sat Oct 06, 2007 1:56 pm Post subject:
Microwave II Manual- for OS 2.33 |
Does anyone know where I can find a manual for the Microwave II- that is as current as OS 2.33?
The manual I have shows 2.28, and the manual on Waldorf's sire which is labeled as 2.3, is the same 2.28.
What are the differences between OS 2.28 and 2.33 (the final OS revision for the MW2)?
thanks |
dasz
Joined: Oct 16, 2004 Posts: 1624 Location: vancouver, canada
Audio files: 29
G2 patch files: 56
Posted: Sat Oct 13, 2007 9:55 am Post subject:
Hey Cappy,
Here is an excerpt from the changelog in the system folder, which funny enough is located here at electro-music's copy of the wealdorf ftp but not currently in the ftp at waldorfmusic.de.
Fri Jan 28 11:23:39 2000 Stefan Stenzel <stenz>
* 2.33 (2.30 to 2.32 only for factory use)
- XTk bugfixes
- XTk Local Control Parameter added
Mon Oct 11 04:39:38 1999 Stefan Stenzel <stenz>
* 2.29
- XTk Arpeggiator bug fixed (hopefully)
- MIDI update less sensitive to sequencer's click and clock
- Support for latest Board revision
Mon Sep 20 08:07:54 1999 Stefan Stenzel <stenz>
* 2.28 (2.27 only for factory use)
- Instrument parameter edit less sensitive
- improved factory test
- minor bugfixes
Fri Sep 10 06:24:38 1999 Stefan Stenzel <stenz>
* 2.26 (2.18 to 2.25 only for factory use)
- System Dump facility added
- Additional Controller for XT Panel Parameters:
FM Amount: 13
Mod1 Amount: 94
Mod2 Amount: 95
-Demo Mode for use with CookBook: <Shift>
-Demo Song (Select Multi #3 in Demo Mode)
-minor bugfixes _________________ http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/ |
cappy2112
Posted: Sun Oct 14, 2007 6:48 pm Post subject:
| dasz wrote: | Hey Cappy,
Here is an excerpt from the changelog in the system folder, which funny enough is located here at Fri Jan 28 11:23:39 2000 Stefan Stenzel <stenz>
- XTk bugfixes
Thanx Dasz. good to know I'm not missing anything.
Factory use eh... I wonder if they have some diagnostic routines in there. |
dasz
Audio files: 29
G2 patch files: 56
Posted: Wed Oct 17, 2007 4:10 pm Post subject:
cappy, I have found one discrepancy.
Ppage 86 of the manual does NOT list F1 Extra as a modulation destination.
Which in fact it the xt v2.33 OS does have, and it is a lot of fun esp on the waveshaper or fm filter modulation. An important omission, I think.
/Dasz _________________ http://www.clavia.se/misc/users/daszgarncarz.htm
cappy2112
Posted: Wed Oct 17, 2007 10:35 pm Post subject:
| dasz wrote: | cappy, I have found one discrepancy.
/Dasz |
Ok thanks |
