nerbaneth
Posted: Thu Oct 11, 2007 9:05 pm Post subject:
Nord 2x Volume levels at low frequencies Subject description: Problems with volume fluctuation |
I am trying to program a sub harmonic frequency bass into the NL2X I made a very good sound, but when I plug it into a mixer and watch the notes as I go higher and lower, the lower I go, I loose volume. The higher I go the louder it gets. This has always been a small problem with other patches, but it has never been this extreme. in in order to hear the low notes, the volume has to be very high, which makes the high notes peak like crazy! I tried sending the signal through a compressor, but the volume change was too great. Is there something else I can do to even the signal levels of the output?
Thank you,
Danny |
Wout Blommers
Joined: Sep 07, 2003 Posts: 4509 Location: The Hague - The Netherlands
Audio files: 123
G2 patch files: 12
nerbaneth
Posted: Wed Oct 17, 2007 11:24 pm Post subject:
can't |
Hi again! (what has happened to the NL2 mailing list!!? all the SPAM!! eep!)
I lost my usb to midi cable at my friends house. for an example try any bass that you can get REALLY low without being able to hear the individual aspects of the oscillator(s) being used( clicking sounds when low) I realized that I am going through a high pass filter, and that changing the filter helps the higher notes go away. the high pass filter is the only one that amplifies the low sound enough to hear without excess external amplification. right now I have the situation solved by an 8 band equalizer the bass being boosted and the highs lowered. this is still a problem for almost all sounds at least slightly.. does no one else get this problem?
Thank you
Danny |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Oct 18, 2007 1:57 am Post subject:
Re: can't |
| nerbaneth wrote: | | Hi again! (what has happened to the NL2 mailing list!!? all the SPAM!! eep!) | Well, that's Yahoo - and no moderator - for you. I'm sure it's good for your sexual performances...  | Quote: | | I realized that I am going through a high pass filter, and that changing the filter helps the higher notes go away. the high pass filter is the only one that amplifies the low sound enough to hear without excess external amplification. right now I have the situation solved by an 8 band equalizer the bass being boosted and the highs lowered. this is still a problem for almost all sounds at least slightly.. does no one else get this problem? | Using a HPF to amplify the low frequencies?
Wout |
nerbaneth
Posted: Wed Oct 24, 2007 11:09 am Post subject:
| Quote: | | I'm sure it's good for your sexual performances... sigh |
Yep its working great
| Quote: | | Using a HPF to amplify the low frequencies? |
it seems strange, but it is the loudest filter.. the LPF makes the sound almost impossible to hear without turning the NL2 all the way up along with the 800W PA
I am kind of happy with the HPF and my equalizer, if I go to really low notes the volume still drops. I am just hoping that this show I am going to play at has a really good PA to amplify to lower notes. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Oct 25, 2007 2:15 am Post subject:
| nerbaneth wrote: | | ... I am kind of happy with the HPF and my equalizer, if I go to really low notes the volume still drops. ... | I think it's very natural for a HPF to lose power concerning the low frequencies...
Wout |
Joined: Apr 03, 2004 Posts: 19583 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Thu Oct 25, 2007 9:08 am Post subject:
A HPF can be very useful for bass boost while keeping some high frequencies. Just set the cutoff frequency to a pretty low value (and maybe make it track the keyboard) and don't set the Q too high. _________________ Jan |
