Simple and small circuit VCAs???
Page 1 of 1 [12 Posts]
numbernone
PostPosted: Tue Oct 16, 2007 9:08 am    Post subject: Simple and small circuit VCAs??? Reply with quote  Mark this post and the followings unread
Hi Ya'll, I am looking for a relatively barebones VCA. Small circuits are best as I want to fir a LOT of them in a small space. I have 2 MFOS double VCA boards populated but they are too big to fit into my current layouts. This seems to be the case with all the MFOS boards, too big for my panels, I think I will likely build an MFOS only suitcase...
Anyhow, can anyone vouch for Rene Schmitz' VCAs?? #2 looks very simple and would condense quite nicely.
numbernone
PostPosted: Tue Oct 16, 2007 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Um yeh, I seem to have overlooked the VCA for the 21st century... DUH!!!
Any suggestions are greatly appreciated, but this one seems to fit the bill nicely.
Photon
PostPosted: Tue Oct 16, 2007 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
The 21st Century VCA is also a filter, which you may or may not want.
You might try Thomas Henrys VCA-1, details at Scott Stites site. I just got parts to build a pair of them myself.
p.
numbernone
PostPosted: Tue Oct 16, 2007 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I will have to investigate it a little further when I get home. I was under the inpression that the VCF and VCA were separate circuits,hmmm... are they truly dependent on each other or just sharing components.
Clack
PostPosted: Tue Oct 16, 2007 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
the soundlab VCA uses very little parts also ( top half )
 Filesize:  22.57 KB
 Viewed:  208 Time(s)
Clacktronics.co.uk
Joel
PostPosted: Tue Oct 16, 2007 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Me too!! Any chance of a link?
numbernone
PostPosted: Tue Oct 16, 2007 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
You have to order the book from Magic Smoke...well worth it. Tons of sweet looking stuff inside.
I always forget that I want to build individual parts of the soundlab, mostly I want a bank of the AR generators. I love to use them as assymetrical LFOs.
Joel
PostPosted: Tue Oct 16, 2007 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the tip Idea
Randaleem
PostPosted: Tue Oct 16, 2007 7:55 pm    Post subject: Re: Simple and small circuit VCAs??? Reply with quote  Mark this post and the followings unread
numbernone wrote:
Hi Ya'll, I am looking for a relatively barebones VCA. Small circuits are best as I want to fit a LOT of them in a small space.
Jorgen's VCA shootout has several designs compared and the simple ones fared pretty favorably. The 13600 versions are begging to be made as dual units. Have a look here: http://hem.bredband.net/bersyn/vca.htm
The SSM2164 is hard to beat if you can use exponential response VCA's. Charlie Lamm's dual PCB layout using Mike Irwin's linear mod gives log/lin responses at the expense of only two VCA's per 2164. Phillip Gallo shows both the expo and linear versions in his extensive writeup on the 2164. (The 2164 has a couple quirks to be dealt with even as an expo VCA. Both the Lamm and Gallo circuits and wrioteups explain and illustrate these needed "fixes".)
Rene's VCA3 is a great little VCA. I believe Ken Stone has a version of it available on PCB too?
Don't forget balanced modulators as VCA's. Trading the cost a 4 quad multiplier chip for a lot of components can let you fit many VCA's in a small space. And you have their "ring" mod capability available as a bonus!
Kind regards,
Randal
Scott Stites
Audio files: 96
PostPosted: Tue Oct 16, 2007 9:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have never been disappointed with a single circuit of Rene's. That guy is one of the greats, IMO.
Come to think of it, the last several Klee samples I've posted were made up of voices largely using his stuff - his version of JH's 2040 filter, VCO3, and the Late MS-20 Filter Clone.
My Site
Scott Stites
Audio files: 96
PostPosted: Tue Oct 16, 2007 10:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
VCA for the 21st century would be a great choice!
My Site
23isgood
PostPosted: Wed Oct 17, 2007 12:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I built two VCA-1's, and they work great. Very simple to build too! I highly recommend it.
pete
Check out my music
