reverbrick
Posted: Mon Oct 22, 2007 4:34 am Post subject:
Looper w. volume control in chuck |
Hello there,
I've tuned one of the basic examples in chuck to have a kind of looper. The code looks like that:
.35::second => dur T;
T - (now % T) => now;
fun void loop(int ch, string smp, int per){
SndBuf buf => dac;
while( true ){
smp => buf.read;
0 => buf.pos;
per::T => now;
spork ~ loop(0,"E:/STUDIO/SAMPLES/JUNGLE-LOOP/SEQUENC170.wav",;
spork ~ loop(1,"E:/STUDIO/SAMPLES/JUNGLE-LOOP/ASHES 170.wav",;
while( true ){
100::ms => now;
//I'd like to control volumes of sporks in here
It run two loops indexed 0 and 1 and what i need is a control of the volume inside the main loop, but I do not know how to do that smoothly.
Please help.
Sorry if the question was already raised as I am new to the forum.
Regards
RR |
Posted: Mon Oct 22, 2007 4:40 am Post subject:
Hi, reverbrick & welcome on board!
Could you re-post your code using the "code' tag and switch off smileys & HTML? The board will muck it all up otherwise.
Where would you like the volume controll to come from? _________________ Kassen |
reverbrick
Posted: Mon Oct 22, 2007 4:59 am Post subject:
Thanks! I've forgot about this tag...I'd like to control volume by midi events later on.
Code: | .35::second => dur T;
SndBuf buf => dac;
while( true ){
smp => buf.read;
0 => buf.pos;
per::T => now;
spork ~ loop(0,"E:/STUDIO/SAMPLES/JUNGLE-LOOP/SEQUENC170.wav",8);
spork ~ loop(1,"E:/STUDIO/SAMPLES/JUNGLE-LOOP/ASHES 170.wav",8);
while( true ){
100::ms => now;
} | [/code] |
Posted: Mon Oct 22, 2007 5:24 am Post subject:
How about using "Envelope" in your signal chain for smooth volume controll using .target() ?
To make those adressable by MIDI I'd turn those instruments into classes. This is not so much extra code and it'll get you super smooth volume tweaks and the controll structure can remain quite clear and simple. _________________ Kassen |
reverbrick
Posted: Mon Oct 22, 2007 5:30 am Post subject:
Thank you for the response...It looks like I've need to learn more about classes.
Best Regards
RR |
Posted: Mon Oct 22, 2007 5:38 am Post subject:
I think classes will suit you as they are very good for what you are doing above already. The big bonus is a name-space that's adressable from outside of them, unlike functions.
Just give a shout if/when you get stuck. _________________ Kassen |
reverbrick
Posted: Mon Oct 22, 2007 5:40 am Post subject:
I'll do so...thanks again! |
reverbrick
Posted: Mon Oct 22, 2007 10:46 pm Post subject:
Kasen, it works! I've put all into class and added midi functionality to controll volume settings of 8 channels thats the code:
Code: | //tempo stuff 140=.212
.2165::second => dur T;
//class
class loop{
SndBuf buf => Gain gai => dac;
0 => gai.gain;
fun void load(string smp){
smp => buf.read;
fun void go(int per){
while( true ){
0 => buf.pos;
per::T => now;
//midi stuff
2 => int device;
MidiIn min;
MidiMsg msg;
if( !min.open( device ) ) me.exit();
//loops
loop l1,l2,l3,l4,l5,l6,l7,l8;
l1.load("sample1.wav");
l2.load("sample2.wav");
l3.load("sample3.wav");
l4.load("sample4.wav");
l5.load("sample5.wav");
l6.load("sample6.wav");
l7.load("sample7.wav");
l8.load("sample8.wav");
spork ~ l1.go(8);
spork ~ l2.go(8);
spork ~ l3.go(32);
spork ~ l4.go(32);
spork ~ l5.go(32);
spork ~ l6.go(32);
spork ~ l7.go(32);
spork ~ l8.go(16);
//main loop
while( true ){
min => now;
while(min.recv(msg)){
//1-8
if(me.arg(0)=="1"){
if (msg.data2==0) msg.data3/127.0 => l1.gai.gain;
if (msg.data2==1) msg.data3/127.0 => l2.gai.gain;
if (msg.data2==2) msg.data3/127.0 => l3.gai.gain;
if (msg.data2==3) msg.data3/127.0 => l4.gai.gain;
if (msg.data2==4) msg.data3/127.0 => l5.gai.gain;
if (msg.data2==5) msg.data3/127.0 => l6.gai.gain;
if (msg.data2==6) msg.data3/127.0 => l7.gai.gain;
if (msg.data2==7) msg.data3/127.0 => l8.gai.gain;
//9-16
if(me.arg(0)=="2"){
if (msg.data2==8) msg.data3/127.0 => l1.gai.gain;
if (msg.data2==9) msg.data3/127.0 => l2.gai.gain;
if (msg.data2==10) msg.data3/127.0 => l3.gai.gain;
if (msg.data2==11) msg.data3/127.0 => l4.gai.gain;
if (msg.data2==12) msg.data3/127.0 => l5.gai.gain;
if (msg.data2==13) msg.data3/127.0 => l6.gai.gain;
if (msg.data2==14) msg.data3/127.0 => l7.gai.gain;
if (msg.data2==15) msg.data3/127.0 => l8.gai.gain;
//<<<msg>>>;
The only thing I'll need to do is somehow smooth the volume change as on some "sound textures" there are noises noticeable during fading. Another one if you see thee script runs with one parameter (1 or 2) it tels the script to be controlled by fader 1-8 or 9-16 because I'd like it to be used for life performance one by one and the problem is when I for example run chuck + script1.ck:1 it runs well and after that i run chuck + script2.ck:2 then audio from script1 stops for a second. Have you got any ideas?
Thanks
RR |
Posted: Tue Oct 23, 2007 3:27 am Post subject:
The audio is probably stopping because you are loading a batch of larger(?) wave files. In the manual is some documentation about making SndBuf load files in chunks instead of all at once, I'd have a look at that if I were you. I see you aren't using stereo so I'd also make sure those waves are mono as that will save you half the file-size already.
For volume glides you could try "Envelope" instead of those gains. then give it a reasonable duration for the smoothing (75::ms or so?) and use .target() instead of ".gain(()", that should give you smooth volume adjustments without a high price. _________________ Kassen |
reverbrick
Posted: Wed Oct 24, 2007 6:37 am Post subject:
I was trying to load lamples in 100::ms, 500::ms and 1::sec periods and it's even worse ... |
reverbrick
Posted: Wed Oct 24, 2007 6:39 am Post subject:
maybe a solution might be filtering clicks? neeee.... |
reverbrick
Posted: Wed Oct 24, 2007 6:46 am Post subject:
got it!!!!
now after understanding what chunks are set 10 => buf=>chunks and it works!!!! smoothly
Thanks again!!!! |
