 Forum index » Instruments and Equipment » Sequencers
New sequencer advice
Page 1 of 1 [3 Posts]
Dovdimus Prime
Audio files: 6
PostPosted: Sat Nov 03, 2007 6:34 am    Post subject: New sequencer advice
Subject description: Looking for very specific sequencer
Hi all
I'm looking for tips and advice about buying a new sequencer program. I'll explain why. I use Cakewalk 9 at the moment, which absolutely meets my requirements apart from the fact that it has a tendency not to save controller data, particularly when it's stored within its own track. Notes - fine. Patch changes - yep. Controller data - depends on the phase of the moon.
So I'm thinking about laying my hands on a new sequencer, as this issue is driving me to distraction. What I'm looking for is really, really simple:
-piano roll view
-simple interface for adding patch changes, controller data, NRPNs etc
-cheap or even better, free!
I'm not really interested in buying some kind of top of the range mega sequencer that has its own effects, can do plugins etc because I will not use it that way. I want it to be a simple MIDI sequencer with an easy to use interface, and no other bells and whistles that I can think of.
If anyone can make any recommendations that would be very helpful.
Thanks
Dovder
This message was brought to you from Beyond The Grave.
PostPosted: Sat Nov 03, 2007 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Tunafish?
http://www.brambos.com/
ACHTUNG!
Dovdimus Prime
Audio files: 6
PostPosted: Sat Nov 03, 2007 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v:
Hmmm. Although it appears to be able to output MIDI externally, I couldn't get it to work and it wasn't mentioned at all in the documentation. I also think 10 tracks may be a little limited for my complex, multilayered musical environmentations.
Thank you for the suggestion though, I appreciate it! Very Happy
Dovder
Niio1
