Layout for Thomas Henry's LM VCO
Page 1 of 1 [11 Posts]
softfin
PostPosted: Thu Nov 08, 2007 3:30 pm    Post subject: Layout for Thomas Henry's LM VCO
Subject description: An Analog Synthesizer for the 21th Century
Here's a layout for Thomas Henry's LM VCO.
The schematic can be found from his book An Analog Synthesizer For the 21th Century.
This is my most complex layout this far, so I can't promise with 100% certainty that it would be free of errors, but I've checked it various times and everything should be ok. I have also built it and verified it works.
C10 is off board and connected directly to the AC/DC switch.
Thanks to Thomas Henry and Magic Smoke Electronics for allowing me to post this, also thanks to Coriolis and Tim Servo for improvement suggestions.
LM_VCO.pdf
 Filename:  LM_VCO.pdf
 Filesize:  965.3 KB
 Downloaded:  1570 Time(s)
xpmtl
PostPosted: Thu Nov 08, 2007 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pin 16 of IC 1 is not connected to anything. Shouldn't it be tied to +15v via a 56K resistor?
http://sdiy.xpmtl.net
softfin
PostPosted: Thu Nov 08, 2007 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for pointing that out!
It seems I accidentally deleted R30 during my last modification of the layout. It's now corrected Smile I also separated the pcb and overlay to two pages and improved the quality of the pdf.
forbin
PostPosted: Thu Jan 29, 2009 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the layout! Worked well...
http://forbinthesynthesizer.blogspot.com/
softfin
PostPosted: Thu Jan 29, 2009 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad to hear that!
Btw, welcome to electro-music!
CJ Miller
PostPosted: Sun May 17, 2009 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
This VCO is very much like the first useful ones I made, but mine were only tri and square. I had made dozens of 555-based oscillators and also used those as linear VCOs. But my layout skills were so poor that my perfboard tries at better VCOs never worked - except as AM radios! I had never soldered any projects bigger than a couple of 555s and I was determined to make an ASM-1 VCO. This was before I had internet to ask anybody, eventually I did it like two years later.
I learned about the 13600 and thought that it looked like one of the most useful synth chips ever... I built a synth out of 13600 VCOs, VCFs, and VCAs. I never enclosed it, the boards just sat on the table. I only got around to experimenting with envelopes around when I moved and put it away, about 1999.
It's making me a nostalgic fool, but these are cool VCOs. Cheap, easy, and they sound great. Mine didn't track so well on the high end, but I was amazed that it even worked. They kept me from throwing in the DIY towel. Also, if you look at the 13600/13700 datasheet, you'll see that this is easily adapted to a quadrature VCO.
adambee7
PostPosted: Thu May 21, 2009 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Could you reupload the PDF. I've tried downloading it but it seems to be corrupted.
adam
Junk Rhythm
PostPosted: Thu May 21, 2009 7:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try downloading again. It just worked for me.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger
adambee7
PostPosted: Fri May 22, 2009 12:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Tried to dowload again but says file damaged or corrupted. I have updated acrobat but still computer says no. will try it on my mates pc later.
PostPosted: Tue May 26, 2009 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
i have these issue here at work from time to time for a few weeks now. did adobe publish a new version again? i am still using AAS 5 here.
but i can open above file without errors!
Tim Servo
PostPosted: Wed Jun 03, 2009 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Tried with Acrobat 5, and could not open the file (errors). Tried with Acrobat 8 and it opened no problem!
Tim (definitely NOT an acrobat) Servo
