5-channel Attenuverting AC/DC Mixer PROFESSIONAL PCBs
Page 1 of 7 [162 Posts]
PostPosted: Fri Nov 09, 2007 11:10 am    Post subject: 5-channel Attenuverting AC/DC Mixer PROFESSIONAL PCBs
Subject description: interest in a 2nd run?
up and running!
this is an attenuverting mixer. one attenuverter for each input. all attenuverted signals where summed, as long as the appropriate single output is not used (switching jack sockets). the summed signal is switchable from AC to DC. in AC mode the summed signal goes goes thru a cap. in DC mode the the cap is bypassed and the signal is also routed to a LED driver indicating the positive or negative parts of the signal.
since there is enough interest i do a run of professional manufactured PCBs, providing MTA connectors for all controls. this is an easy to build project, no obsolete, expensive or hard to find parts.
the boards should be available on 10 DEC 07. i will populate and test at least one PCB before taking money, paypal preferred.
pricing (preleminary):
europe
9.-EUR each PCB
+1x p&p 3.-EUR (2.50EUR germany)
worldwide
13.-USD each PCB
+1x p&p 7.-USD
so here is the documentation (EDIT: draft v2):
draft v2
PCB preview:
Posted Image, might have been reduced in size. Click Image to view fullscreen..
PROTOTYPE v1
PROTOTYPE v1
PROTOTYPE v1
Scott Stites
Audio files: 96
PostPosted: Fri Nov 09, 2007 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Very sweet and I'd wager will turn out to be one of your most used modules!
My Site
Etaoin
PostPosted: Fri Nov 09, 2007 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
For a moment I thought I had found a use for my center tapped pots, but it appears not...
But I need at least two of these anyway I fear Very Happy
By the way, is that still unprotected copper?
http://www.casia.org/modular/
Peake
PostPosted: Fri Nov 09, 2007 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Congratulations!
If you make PCBs for the public (hint hint! Very Happy ) I'd have an immediate use for two of them. Maybe more.
prophei
PostPosted: Fri Nov 09, 2007 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Peake wrote:
Congratulations!
another great module! i would put myself in the same place as mr. peake here... at least 2 of them!
slo
PostPosted: Fri Nov 09, 2007 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lovely module, well done, I like the LED's touch, you cannot have enough blinky lights in my opinion.
Rykhaard
PostPosted: Sat Nov 10, 2007 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Unprotected copper?? Wink Does that mean that I SHOULD be spraying each of my self-made PCBs with the conformal coating silicon spray that I bought, 2 years ago - and haven't gotten around to using yet? Very Happy
(Serious question. Just looking for input. Smile )
Rykhaard
PostPosted: Sat Nov 10, 2007 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Heh. Check out the videos of my modular in the Design section of my webpage: http://deathlehem.com/wsb4569662402/design.html
Lots and lots of blinky lights. Very Happy (Will be many more coming, in my MFOS Sequencer and Klee sequencer. Very Happy )
PostPosted: Sat Nov 10, 2007 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Rykhaard wrote:
Etaoin wrote:
...By the way, is that still unprotected copper?
protect from what? it is soldered so i would not care about stain...
fonitronik at
Rykhaard
PostPosted: Sat Nov 10, 2007 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
That's part of my curiosity. I do have 1 PCB prototype for a multiple-vowel filter that I'd done in '95 or so. The copper has held out fine. Barely tarnished.
Curious as well as - I've done 1 panel, using 1 of the many 15"x9" single sided copper boards that I have - for mounting controls to. I'm seriously considering using another to mount the controls for my MFOS Sequencer to. Gives a nice look. Smile Wondering there - if I should coat it with my sili. spray. There though - I don't know if the spray has any flexibility - which the panel itself would have happening - when switches are used; plugs pushed in / pulled out. Hmmmmm ..... ???
Etaoin
PostPosted: Sat Nov 10, 2007 9:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Protect from the environment. I just repaired a Korg M500. The component side of that PCB is also not protected and it had many tracks turned green and eaten away by corrosion.
It would depend on your environment though. This Korg was probably stored in the wrong place.
softfin
PostPosted: Sat Nov 10, 2007 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I bought some protective laqcuer and have recently sprayed my pcbs with it.
Smells terrible, so if anyone decides to use such spray, it's definately better to spray it anywhere else but not inside your house.
Etaoin
PostPosted: Sat Nov 10, 2007 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I use a PCB coating from Kontakt that smells like paint (and not the water based ones) only more intensly so. I can hardly use that indoors either.
Pehr
PostPosted: Sat Nov 10, 2007 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't think I've actually got what an attenuverter is... Embarassed
Is it an attenuator followed by an inverting op amp? Confused
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Danno Gee Ray
PostPosted: Sat Nov 10, 2007 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there a schematic for this unit available? I'm curious as well.
EDIT...Duh Just re-read the top post and saw that it says "Schematic will be uploaded soon".
PostPosted: Sat Nov 10, 2007 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
he he. an attenuverter gives both: attenuation of the original and the inverted signal. say pot in middle position: no signal, pot clockwise: original signal, pot counterclockwise: inverted signal. in other words: each channel allows you to invert and/or attenuate the signal...
fonitronik at
fluxmonkey
PostPosted: Sat Nov 10, 2007 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
ken stone shows one way of doing something similar on his DC Mixer page... the additional pots in red... but i really like your inclusion of individual outs, fonik.
actually, you could implement this using a pair of ken's Dev-mod Mixer/Inverter blocks... i keep on thinking of uses for those, gotta pick some up next order.
yet another addition to the "to do" list (happy sigh).
b
Pehr
PostPosted: Sun Nov 11, 2007 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice! Cool
YouTube channel
flickr photostream
Sound
PostPosted: Sun Nov 11, 2007 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Congratulations fonik,
Four for me Very Happy
Is difficult to add an "all input" for multiplying signals?
PostPosted: Sun Nov 11, 2007 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
ken stones circuit (red components) allows no attenuation: you just fade the signal from pos to neg (or inverted). my module gives both, attenuation and, if desired, invertion.
fonitronik at
PostPosted: Sun Nov 11, 2007 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
certainly not! that would be just a multiplier: add a socket and wire it to all individual inputs (you may want to use switching sockets here as well).
fonitronik at
frijitz
Audio files: 54
PostPosted: Sun Nov 11, 2007 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Not following what you are saying. In Ken's unit, the signal is zero when the pot is centered. So it looks to me like it both attenuates and inverts.
Ian
PostPosted: Sun Nov 11, 2007 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Ian
Embarassed thank you, ian. so the signal actually cancels itself out? is that correct?
fonitronik at
frijitz
Audio files: 54
PostPosted: Sun Nov 11, 2007 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right. With the pot centered equal signals are sent to "B" and "C", one of which inverts, so the two branches cancel.
Scott Stites
Audio files: 96
PostPosted: Sun Nov 11, 2007 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
A spiffy variation would be to normal +5V (or more) through a 1K resistor to one of the input jacks. That gives you the ability to offset the mix +/-5 Volts (or more) when mixing CVs without plugging a DC voltage in. Of course, plugging something into that input would disable the DC function and handle the signal as usual.
For example, that would be handy for inverting an EG applied to one input, and offsetting it + with the normalled control, or putting a DC offset to a bipolar LFO for trill fx on a VCO.
Banana jackers (or non-bananjackers) could switch the offset in with a switch.
Ciaorioios,
Scott
My Site
