The best way to make beautiful Goa/Trance gate effect ?
Page 1 of 1 [8 Posts]
onosendai
G2 patch files: 4
PostPosted: Tue Nov 13, 2007 4:28 pm    Post subject: The best way to make beautiful Goa/Trance gate effect ? Reply with quote  Mark this post and the followings unread
Hello !
I don't know if you listen some Goa/Psychedelic Trance but they use a lot of gate effect to create crazy sound. I've tried to reproduce that with my G2 but i can reach the clean, cutting effect of pro tracks like Infected Mushroom does.
Have you some idea to work with ? What will you do to cut a trance lead sound into rythm part.
My 2 cent with this patch, but it's not exactly the effect i want.
GoaSetup.pch2
I've tried to make gating effect... but it's not really that
This patch work with the demo.
 Filename:  GoaSetup.pch2
 Filesize:  3.43 KB
 Downloaded:  1186 Time(s)
deknow
PostPosted: Wed Nov 14, 2007 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
if i understand what you are going for (which i might not), i think what you want is to mash up the sound a bit more _before_ the gating. try something like this (which is just slightly modified from yours):
deknow
goasetuprevised.pch2
 Filename:  goasetuprevised.pch2
 Filesize:  3.58 KB
 Downloaded:  1414 Time(s)
onosendai
G2 patch files: 4
PostPosted: Wed Nov 14, 2007 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
It's not exactly about the sound, it's much about how to trigger or gate the sound.
Go there : http://www.deezer.com/ search "infected mushroom", and listen the track "Ratio Shmatio". At 1.20, you will heard a sound triggered nicely... but i don't know how. Enveloppe ? Gate ? Just midi programming ? How do they create this "high-speed-cut-gate" effect witch i love but can't reproduce
EDIT : at 2.25, i love this gate effect ! Do they retrigger all the enveloppe or just gate the master volume in sync with a LFO ?
X-Electric
PostPosted: Wed Nov 14, 2007 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you talking about that short lead-rush thingie? (I don't hear any other 'gated-lead-like' sounds there) If so, why do you imply it had to be done on a synthesizer? It could easily be a truncated lead attack sample played back on any sequencer with 32nd or 64th note fill.
onosendai
G2 patch files: 4
PostPosted: Wed Nov 14, 2007 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hum... maybe Very Happy Good clue.
deknow
PostPosted: Wed Nov 14, 2007 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
tried to listen to the sample you referred to, but it only goes up to 1min, so i can't hear what happens at 1min20sec.
deknow
emeleia
G2 patch files: 5
PostPosted: Tue Nov 20, 2007 3:33 pm    Post subject: nothing's goasetup Reply with quote  Mark this post and the followings unread
hi, i have heard a lot this kind of effects on many trance songs. there are many ways for achieving what you want. actually i read on the web how infected does it with cubebase, but i don't use that sequencer, i use live. When i tried to do it i routed the track out of a Pad that i recorded on live and passed it through the g2. i used a gate module, that was controlled by seq modules, and filters modulated by env modules.
I made some changes to your patch maybe it is what you expected..
P.D. i think i will use this patch too Very Happy
cheers
Nothing-goasetup.pch2
 Filename:  Nothing-goasetup.pch2
 Filesize:  4.18 KB
 Downloaded:  1089 Time(s)
emeleia
G2 patch files: 5
PostPosted: Tue Nov 20, 2007 7:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm agree with that
