Post Your KLEE Panels Designs Here
Page 10 of 12 [298 Posts]
Goto page: Previous 1, 2, 3, ..., 8, 9, 10, 11, 12 Next
a.b.o.z.
G2 patch files: 4
PostPosted: Fri Jun 27, 2008 9:08 am    Post subject:   Reply with quote  Mark this post and the followings unread
scott where is your klee?
Smile
i'm only 400km from mine Very Happy
i'm in my wifes home town down on adriatic coast.
it is darn hot. juck Razz
Audio files: 25
PostPosted: Fri Jun 27, 2008 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
I would replace the sliders with a switch of some type.
At least for the method of how I use the Klee, I'd have to disagree. This would sort of kill things for one step sequences. For the higher range sequences, the small adjustments do make quite a bit of difference.
What Scott is saying makes a lot of sense, and he has been using his Klee alot more than I have, so I will humbly make a 180degree turn on the "lose the sliders" opinion, and bow to the experience of my learned friend. Very Happy
If you don't sing in a government choir,
and you forget why you got hired,
you can warm your hands on friendly fire.
- John Foxx
Luka
PostPosted: Fri Jun 27, 2008 8:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
that panel looks great thomas, the line of switches is good thinking, i might re-make my panel based on that design while im still waiting for money to buy panel components
problemchild
melbourne australia
Scott Stites
Audio files: 83
PostPosted: Fri Jun 27, 2008 10:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, actually Andy, it's not such a bad idea - it may work quite well for others. I think we'll find that one person's Klee is another's Clover Laughing
My Klee is in Kansas, but I'm in Penang, Malaysia right now for a good long time ('til end of July). Not sure if it's *really* 10,000 miles, but I figure it's close to that. I'm closer to Andy's Klee than to mine.
Hmmmm.........
I'm not quite clear about what you just spoke
Was that a parable, or a very subtle joke?
- Brad Roberts
My Site
Scott Stites
Audio files: 83
PostPosted: Fri Jun 27, 2008 10:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I keep forgetting to mention that is one spankin' badass circular panel! Very nice indeed.
- Brad Roberts
My Site
Audio files: 25
PostPosted: Sat Jun 28, 2008 2:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmmm.........
Well,.... It's only a little flight down to Brisbane. Then a connector to Coffs Harbour. You get weekends off don't you? Charge work for it. Research and Development it's called. You can research the state of SDIY in Nambucca Heads, and we can develop a hangover together! Laughing
- John Foxx
sduck
PostPosted: Thu Jul 03, 2008 8:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
So here's mine. I probably get the award for ugliest klee panel yet.
Folks who also look in the modularsynthpanels yahoo group have already seen this, and the .fpd file is available there - I can post it here also if there's any interest.
I just wanted something that would fit right into my otherwise mostly motm format synth. It's actually Clickmrmike's design, with some slight tweaks of the switch positioning and labeling. I basically took an old milton panel design and modified the bottom of it.
Apologies for getting the electro-music Klee label wrong - I didn't read all of the applications and build thread until after I designed it.
So anyway, this panel is on its way to me from Seattle as of now, and I've got the boards half stuffed, and many of the panel parts are here or are on the way also. When I posted this design on modularsynthpanels, it seemed to get things going, and Thomas White did his amazing oval design, which'll also work for my purposes, so I'll probably end up getting one of those once Scott Deyo starts producing them cheaply. I like this straightforward, linear design, but I also really like the oval design - one can have 2 klees, right? This is assuming that eventually there'll be a third board run (hope!).
Screen capture of my klee panel in front panel designer
 Filesize:  144.47 KB
 Viewed:  83 Time(s)
PostPosted: Fri Jul 04, 2008 1:51 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
bugfight wrote:
was it the sparkfun 4x4?
http://www.sparkfun.com/commerce/product_info.php?products_id=7835
they are kinda big...
BINGO! thank you so much!
these seem to be momentaries, aren't they? i am not quite sure about the mechanical details anyway. how do they work?
cheers,drunken
pix of my work at flickr
mono-poly
PostPosted: Wed Jul 09, 2008 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Wiard Klee
wiard klee
 Filesize:  259.99 KB
 Viewed:  84 Time(s)
Audio files: 6
PostPosted: Wed Jul 09, 2008 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wiard Klee
Very very nice design Mono-Poly !!! All these great front panel iterations, there should be a Klee picture book made up Very Happy
Bill
sduck
PostPosted: Wed Jul 09, 2008 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
mono-poly wrote:
Wiard Klee
That is really nice. Is that an official Wiard implementation of the klee, or a look-alike version?
mono-poly
PostPosted: Thu Jul 10, 2008 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
It is DIY for in my Wiard setup.
Scott Stites
Audio files: 83
PostPosted: Thu Jul 10, 2008 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Man, that is just absolutely beautiful.
- Brad Roberts
My Site
bugfight
PostPosted: Tue Jul 15, 2008 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry, i've been out of town and missed this.
yep they're momentaries.
there's conductive carbon on each silicon button and it contacts a pad on the pcb.
cool, sparkfun finally added diode pads to their pcb (to avoid ghosting in matrix switch circuits). i wound up making my own pcbs...
Luka
PostPosted: Thu Jul 17, 2008 7:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
well here is my contribution
my modular panel material is a bit different from most,
im using rusty steel that i have found around our warehouse.
so here is my rusty klee.
sorry about photo quality
im still waiting for my switches,
then ill finally check the circuit build for any problems.
so excited !
cant wait to hear this baby in action
problemchild
melbourne australia
sduck
PostPosted: Thu Jul 17, 2008 7:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
At first glance I went "ewww, that's some serious funk". But then I found I couldn't look away - that panel has some serious depth, and looks like it'll be real fun to use. Cool variant on the steampunk thing. Thanks for sharing!
Luka
PostPosted: Thu Jul 17, 2008 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah its a bit grimey. but i kinda like that
one day ill have some cash and ill get some aluminium panels cut for all my panels, for now i like the industrial rust edge. this machine is going to make good noise so rust fits in with that theme Smile
problemchild
melbourne australia
seraph
Editor
Editor
Audio files: 15
PostPosted: Fri Jul 18, 2008 12:34 am    Post subject: Reply with quote  Mark this post and the followings unread
it looks like some ancient time machine Shocked hypnotic Exclamation
Wink
homepage - forum - myspace - virb - berkleemusic
I am so clever that sometimes I don't understand a single word of what I am saying. - Oscar Wilde
Sound
PostPosted: Fri Jul 18, 2008 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
OH! Luka! Its amazing!
Please, could you upload a high resolution picture? I would like to look your klee more detailed!
Could you explain how you do your front panels a little bit?
Luka
PostPosted: Fri Jul 18, 2008 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, ill try find a camera (and ill chuck into this post)
Basically i found lots of sheets of 1mm steel which were rusty as hell (only surface rust and only slighty correoded on one side). i pulled out our angle grinder and cut it to measure a moog unit system. desinged the panel in photoshop ( i actually designed it for brass but i made it in rust to suffice for the moment but i think ill keep a whole cabinet in rust now )
drilled the holes with a drill press, and labeled it by hand with a sharpie. drilling wasnt too hard, it was a lot easier than i expected however i never had drilled much aluminium before this. after making some aluminium panels for other people i must say it is so malable and easy to work with Smile
so then i added led bezels and some cheap knob that im using for my whole cabinet. now waiting for switches. (200 on the way) i hate waiting for international deliveries Sad
i have an enitre rack near completion of modular done in rusty steel. i like it a lot. it is a good means of recycling, it looks a lot different to most people's modular systems, and it is so much fun using angle grinders and heavy metal tools Smile it also has a industrial edge and seems fitting for a modular synth.
attached is my design, soon to come high res pictures if i find a camera
the rust has a really amazing natural corrosion patterns so ill put some time into take the photos right once i find a camera
klee panel design, ive changes a few slight things when i drilled and marked the panel
main differences are the position of the merge T&G, the colour of the LEDs, and that i wont be using push buttons for the inner row of switches (obviously the switc
 Filesize:  77.51 KB
 Viewed:  33 Time(s)
problemchild
melbourne australia
sduck
PostPosted: Fri Jul 18, 2008 8:03 pm    Post subject:
Subject description: my klee, part 2
Ok, here's 2 pics of my ugly duckling klee in it's current state. Just a ton of wiring to do yet. I wanted to get a halfway decent pic as I'm off on vacation next week, and won't be able to work on the thing, and need a pic to keep my head in the game. I just threw the knobs on loosely for the picture - don't want to mess them up while soldering tons of wires on the back - but also wanted to have a feel for how the thing will look like completed, and so I could fulfill the instructions on the bottom of page 21.
 Filesize:  1.49 MB
 Viewed:  46 Time(s)
 Filesize:  1.53 MB
 Viewed:  26 Time(s)
Luka
PostPosted: Fri Jul 18, 2008 9:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
im really not looking forward to wiring the beast ;; sigh
have a nice holliday sduck Wink
problemchild
melbourne australia
Audio files: 6
PostPosted: Sat Jul 19, 2008 5:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Been looking at the panels guys and I continue to be amazed at the variations ....... great work to all !!!! I love it Wink
Bill
softfin
PostPosted: Wed Jul 23, 2008 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I finally bite the bullet and designed a panel for my Klee. Very Happy
I used Fonik's panel layout as a starting point and modified it quite a bit to better suit my tastes (bigger sliders).
The price estimate for the panel was a positive surprise: it will probably cost only a little more than 100eur Smile
 Filesize:  118.65 KB
 Viewed:  49 Time(s)
http//www.myspace.com/softfactor
Rykhaard
PostPosted: Wed Jul 23, 2008 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
That panel looks WILD!! Very Happy And it's JUST inspired me as well! Since I use wood for my panels, I'm going to search around / keep my eye open to see if I can find any flat BARK, in any type of wood. I love the look of yours extremely, especially in the Industrial (mechanical and musically) frame of mind! Twisted Evil At the very least, for future art on my panels, I'm going to keep the 'industrial' in mind, pictures wise! Smile
Now - the other reason for replying - 200 switches?? From WHERE? How much??? With all of the sequencers that I have planned at the moment (2 more Ray Wilson MFOS sequencer digital boards, just arrived in the mail - weeeee! Smile ) I'm going to need at least 100 each of ON/ON and ON/OFF/ON switches. I'm looking for great priced sites.
Where are your 200 coming from and if eBay - please let me know when they arrive; how long they took to ship and their cost! Smile
Rych
http://www.damian.deathlehem.com/ - home of my modular synth
http://www.rykhaard.com/ - my personal homepage - with 89 of my tunes I`ve writ
http://www.molindarius.com/numerology - my Numerology site with my Numerology software
