Help again with level sequencer :)
Page 1 of 1 [5 Posts]
AntonyPath25
PostPosted: Fri Nov 30, 2007 1:09 am    Post subject: Help again with level sequencer :) Reply with quote  Mark this post and the followings unread
Hi again !!! Smile
i need help about the connection of a level sequencer in a very simply sound !! can someone make for me an example in my patch
Thanx Smile
level seq quest.pch2
 Filename:  level seq quest.pch2
 Filesize:  1.17 KB
 Downloaded:  610 Time(s)
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Fri Nov 30, 2007 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice sound.
Using a level sequencer with a polyphonic patch is probably best done with internal midi. If you put the level sequencer in the VA of a polyphonic patch then the sequencer is duplicated along with the voice.
The attached example uses the FX area for the sequencer and midi send module. The same midi send module can also send a velocity value, in this case to provide a slightly random filter frequency for each note.
Load into slot A.
level_seq_quest_119A.pch2
 Filename:  level_seq_quest_119A.pch2
 Filesize:  1.76 KB
 Downloaded:  711 Time(s)
darwen
G2 patch files: 5
PostPosted: Sat Dec 01, 2007 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Very good example , i don't all understand because i'm very misunderstood with midi module like switch and logic modules my patches always used the rest of the modules exept those.
Thanks for the example my solution was very bad in comparison of yours. Smile
Audio files: 116
G2 patch files: 317
PostPosted: Sat Dec 01, 2007 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I moved this to the general discussion, the patch subsections are really meant for finished patches.
kcinsu
G2 patch files: 6
PostPosted: Sat Dec 01, 2007 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was a little bored, and I liked the sound and little melody that was added... so I just went with it.
Enjoy!
There are patch variations as well (although subtle)
SeaQuest.pch2
 Filename:  SeaQuest.pch2
 Filesize:  3.82 KB
 Downloaded:  647 Time(s)
JuneSolstice2013
