Presentation & My first chuck program
Page 1 of 1 [3 Posts]
Marotte
PostPosted: Mon Dec 03, 2007 1:11 pm    Post subject: Presentation & My first chuck program
Subject description: Hi Everybody. Request for comments
I read a lot of your posts since some weeks and I told myself I have to write something...
I use to make sounds with computer using some more "user-friendly" softwares like LMMS and ZynAddSubFX, and, appart of that I'm a computer scientist with nothing to code right now. I told myself it's should be a good thing to me to learn a programing language I do not know... But, what to program ? And then, I discovered chuck so I can learn a language and make sounds in the same time :)
I always found difficult to produce a kick drum line in the softwares I tried, and most of the time you must write a sequence from 0 to the end, without some repeating functionalities.
Let's see the code, I hope it should work on a maximum of plateform.
Code:
// First attempt of a kick drum generator by Marotte
minute / samp / 60 => float samplerate;
class Kicker
   // Polyphony
   16 => int voicemax;
   // Timing utilities
   140. => float tempo;
   minute / tempo => dur b;
   4 * b => dur t;
   // The patch
   SinOsc voice[voicemax];
   ADSR env[voicemax];
   .4    => float gain;
   380.  => float startfreq;      // Default startfreq is 200 Hz
   60.   => float endfreq;        // Default endfreq is 60 Hz
   b/4   => dur decay;            // Default decay is a quarter of beat
   1.    => float dropdown;       // Coef for exponential frequency dropdown
   .06   => float gainran;        // gain randomness
   5     => float sfreqran;       // startfreq randomness (Hz)
   5     => float efreqran;       // endfreq randomness (Hz)
   10.   => float decayran;       // Decay randomness (ms)
   5::ms => dur attackTime;
   5::ms => dur releaseTime;
   Dyno limiter; limiter.limit ();
   fun void init ()
   for (0 => int i; i < voicemax; i++)
       startfreq => voice[i].freq;
       voice[i] => env[i] => limiter => dac;
       attackTime => env[i].attackTime;
       releaseTime => env[i].releaseTime;
       // Let's start with all ADSR at "done" state as we will use "ADSR.state()==4" to select a free voice.
       voice[i].gain (0.); env[i].keyOn (); env[i].keyOff (); releaseTime => now;
       gain => voice[i].gain;
     <<< "Patch ready" >>>;
   init ();
   fun int freevoice()
        for (0=> int i; i < voicemax; i++)
            if (env[i].state() == 4) return i; // Cool, we find one.
        // No free voice, look for a voice in "release" state
            if (env[i].state() == 3) return i;
        // No voice in "release" state !
        <<< "No voice available !" >>>;
        return Math.rand2(0,voicemax); // Better solution ?
   fun void play ()
        freevoice() => int cur;
        0. => voice[cur].phase;
        startfreq => voice[cur].freq;
        Math.rand2f (-sfreqran, sfreqran) => float sfreqoffset;
        startfreq + sfreqoffset => voice[cur].freq;
        gain => voice[cur].gain;
        Math.rand2f (-gainran, gainran) => float gainoffset;
        voice[cur].gain() + gainoffset => voice[cur].gain;
        if (voice[cur].gain() < 0.0001) voice[cur].gain()  + .001 => voice[cur].gain;
        Math.rand2f (-decayran, decayran) => float decayoffset;
        now + decay + decayoffset::ms => time end;
        Math.rand2f (-efreqran,efreqran) => float efreqoffset;
        env[cur].keyOn ();
<<< "Voice ",cur, " GAIN: ", voice[cur].gain(), " START F: ",startfreq + sfreqoffset, " END F: ", endfreq + efreqoffset, " DECAY: ", 1000 * (decay + decayoffset::ms) / samplerate, " ms" >>>;
         while (now < end)
           if (endfreq <= startfreq)
            if (voice[cur].freq() >= endfreq + efreqoffset)
               voice[cur].freq() - dropdown * Math.exp (1 / voice[cur].freq()) => voice[cur].freq;
            samp => now;
            else
            //<<< voice[cur].freq () >>>;
            if (voice[cur].freq() < endfreq - efreqoffset)
               voice[cur].freq() + dropdown * Math.exp (1 / voice[cur].freq()) => voice[cur].freq;
            samp => now;
         env[cur].keyOff (); //<<< cur, " OFF|", " Now : ", (now / samp) / samplerate, " second" >>>;
   fun void loop (float periode, float playtime, float holdtime, float length)
        periode * t  => dur per;
        playtime * t => dur pt;
        holdtime * t => dur ht;
        length * t   => dur len;
        now + len => time endloop;
        while (now < endloop)
           now + pt => time stop;
           while (now < stop)
              spork ~ play ();
              per => now;
           ht => now;
        decay => now; // Let the last sporked play () to finish and do the last keyOff ()
Kicker k;
150. => k.tempo;
40. => k.decayran;
.5 => k.gain;
.3 => k.dropdown;
k.b/3 => k.decay;
30. => k.sfreqran;
210. => k.startfreq;
k.init (); // Don't forget to init () after you set some Kicker's values
// Not used in this exemple, but "inversed kick" (with startfreq < end freq) should work...
//Kicker pouet;
//.00001 => pouet.gainran;
//150. => pouet.tempo;
//.3 => pouet.dropdown; // In this case, down = up :)
//.009 => pouet.gain;
//pouet.t/8 => pouet.decay;
//60. => pouet.startfreq;
//1800. => pouet.endfreq;
//150. => pouet.efreqran;
//pouet.init();
2*second => now; // Mmmmh...
while (1)
spork ~ k.loop (.25,5,0,64);
spork ~ k.loop (.1,.25,3.75,60);
spork ~ k.loop (.03,.1,5.9,60);
hour => now;
<<< "RESTART" >>>;
Please let me know what do you think about it.
Edit by your friendly editor Kassen; I switched on BBCode for this post as this made the "code" tag stop working which in turn gots rid of the tabs. BBCode==good, HTML==bad (at least for posting code here). Cheers
kijjaz
PostPosted: Mon Dec 03, 2007 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow this is a nice poly synth and the groove is good.
It sounds quite variable, and interesting.
Cool. I'll look forward to your new experiments and patches ^_^
or let's share some new ideas.
Inventor
Audio files: 37
PostPosted: Wed Dec 05, 2007 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Haha, you posted to the right place. Kijjaz is the drum master, he makes all the groovy sounds! The two of you should have a blast with this. I'd join in, but I'm hot and heavy on another project right now. Good luck and welcome!
Top Selling Products! CLICK HERE!
