Error in instructions for G2 expansion board.
Audio files: 107
PostPosted: Thu May 27, 2004 11:02 am    Post subject: Error in instructions for G2 expansion board. Reply with quote  Mark this post and the followings unread
G2 bottom showing the second screw you need to remove to get the synth to open up
I received my G2 expansion board today and installed it. The serial number for the board is GA10099. The was a significant error in the instructions that caused me some problems. I hope by posting this we can save someone else grief.
On step 2, the instructions state: Remove the larger black screw on the bottom of the synth (underneath the Mod Wheel).
I did this, but was unable to pull up the lid. It turns out, you also have to remove another larger black screw as well. I have indicated this on the picture.
Other than the installation went well, except that it took me a minute to figure out how to orient the expansion board with respect to the internal components. That is because the serial number sticker was put on a differnt chip on my expansion board than is show in the photo in the instructions.
I now get 23 voices of polyphony when using the factory patch BriteTine which is in the Piano category. I'm not sure how many I got before.
I hope this helps.
