Internal split
dbo
PostPosted: Sun Dec 30, 2007 9:42 am    Post subject: Internal split Reply with quote  Mark this post and the followings unread
2 osc pwm with internal split function (green section)
Internal split is a function that allows the user to split the keyboard in two zones, causing probably a pitch gap. It could be very usefull for live use of the 37keys version of G2. The user can control the split point and the left zone tune.
When the "octave shift" button is at the center point and "split point" has value "0" then the split point is E4. The "left z tune" defines the semitone shift of the left zone. If the "left z tune" has value -12 then the left zone is one octave lower.
Analog pwm split.pch2
 Filename:  Analog pwm split.pch2
 Filesize:  2.93 KB
 Downloaded:  1285 Time(s)
