 Forum index » Instruments and Equipment » Reaktor
Breath-controlled physical modeling ensemble available
Page 1 of 1 [4 Posts]
Chet
G2 patch files: 35
PostPosted: Sun Jan 06, 2008 6:24 am    Post subject: Breath-controlled physical modeling ensemble available Reply with quote  Mark this post and the followings unread
I've created a breath-controlled physical modeling ensemble that mimics brass and woodwind instruments. It's called Silverwood, and is available in the Reaktor User Library at http://www.native-instruments.com/forums.html?id=userlibrary&type=0&ulbr=1&plview=detail&patchid=6734
It really is breath-controlled, though. Without a breath or wind controller, it sounds like water evaporating.
Attached is an example of some breath-controlled double reeds.
Silverwood_Double_Reeds.mp3
Handel hornpipe using double reeds
 Filename:  Silverwood_Double_Reeds.mp3
 Filesize:  1.23 MB
 Downloaded:  291 Time(s)
Chet
G2 patch files: 35
PostPosted: Sun Nov 09, 2008 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
The ensemble now includes a model of a Hammond organ. The model includes harmonic foldback, percussion, key click, chorus, and drawbars that can morph.
A 'KB Test' button has been added, which lets the models be auditioned from a standard MIDI keyboard, eliminating the need for a breath or wind controller.
The ensemble can be found in the Native Instruments Reaktor User Library at http://www.native-instruments.com/forums.html?id=userlibrary&type=0&ulbr=1&plview=detail&patchid=7742.
Screen shot of the organ model.
 Filesize:  182.92 KB
 Viewed:  127 Time(s)
Screen shot of the flute model.
 Filesize:  184.22 KB
 Viewed:  133 Time(s)
SilverwoodV3.zip
The ensemble itself.
 Filename:  SilverwoodV3.zip
 Filesize:  2.69 MB
 Downloaded:  170 Time(s)
BobTheDog
PostPosted: Sun Nov 09, 2008 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow this looks nice, downloading now.
Andy
ew
PostPosted: Mon Nov 10, 2008 11:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work, Chet Smile
You're one of the only people who does physical modeling with Reaktor, and you always come up with something interesting.
Well done!
ew
AmbiphonicDSP
