Problem with OSC in Ubuntu
Page 1 of 1 [3 Posts]
conexionismo
PostPosted: Tue Jan 22, 2008 3:56 pm    Post subject: Problem with OSC in Ubuntu Reply with quote  Mark this post and the followings unread
With Ubuntu 7.04 in a i386 machine i install the deb package Chuck 1.2.0.7 Linux (jack) ans works fine except the OSC protocol.
Print this error: undefined type OscRev
Thanks => now;
PostPosted: Wed Jan 23, 2008 1:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmmm, where does the "OscRev" come from? That should likely be "OscRecv", could you try that? If that's not it things may get complicated.
I'd also recommend that you think about updating the version on ChucK that you use. I realise compiling your own is a lot less convenient then getting a package but since version 1.2.0.7 there's been a lot of progress. That's all up to you, of course.
while(!machine.crash() ) <<<"all is well">>>;
conexionismo
PostPosted: Sat Jan 26, 2008 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it's OscRecv, but no work.
I try to compile the last version and no problem.
Once You Know, You Newegg
