Niksa
Joined: Feb 19, 2008 Posts: 3 Location: Georgetown, Ontario
Posted: Wed Feb 20, 2008 3:34 pm Post subject:
Direct recording with Mac |
Hi all,
My PC has recently crahsed pretty hard, and I've been tempted to buy a mac for years. I'm looking at the iMacs currently, but was wondering if anyone has any opinions on direct recording with them. I use a tascam US-122 to record onto my PC, and from what I can tell the drivers are there for the MAC OS.
Does anyone have experience doing direct audio recordings on there? I know Garageband is the big one for recording live instruments, but hardware wise, any problems with mac? |
Posted: Wed Feb 20, 2008 5:57 pm Post subject:
The iMac will do fine. I haven´t used one myself, but basically it is a Mac with one internal hard drive. The rules are the same as for any one drive system out there. You must keep your disk reasonably clean. It is too easy to fill it up with pictures from your digicam, MP3s and what have you. If you intend to use a computer as a DAW, then you must consider what else you are using it for.
I dunno about that audio interface you have, but if the vendor provides OS 10.5.x compatible drivers then I´m sure it will work just fine.
Garageband is OK as a low end DAW. It´s main focus is as a host for a lot of sample/loop based virtual instruments but it can do live capture OK as well.
For almost nothing you can get the light version of Logic. This is a pretty serious DAW and the full version at 399 USD is awesome. Another alternative is Digital Performer ( MOTU ). _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Drone
Joined: Feb 06, 2008 Posts: 59 Location: The Great White North
Posted: Sat Feb 23, 2008 7:09 pm Post subject:
Re: Direct recording with Mac |
Niksa wrote: | Hi all,
I use my girlfriends I-mac & also have a macbook pro.
If you get a good AD/DA converter with solid drivers, you can't go wrong !
-Erik _________________ It is at least ten times more difficult to get a good synthesizer sound than on an acoustic instrument. - Giorgio Moroder |
