LFLab
Joined: Dec 17, 2009 Posts: 142 Location: Rosmalen, Netherlands
Posted: Mon Dec 12, 2011 1:26 pm Post subject:
| I'm building a quad of these using the dual Bugbrand layout. Stuffed the boards but haven't tested them yet. I was wondering about these caps as well, used 3u3 filmcaps. If it works with electrolytics it'll work with flmcaps. I think the envelope generators are unipolar so electrolytics should be ok, i put in film just to be shure. |
frijitz
Audio files: 54
Posted: Mon Dec 12, 2011 1:32 pm Post subject:
| furio wrote: | My pots are 100KA and 500KA.
I have some difficulty to choose the cap values
With the first attempt I used C1 4u7 and C1x 470nF and now C1 1uF and C1x 1nF. But I think there is no end, the envelope is still running non-stop! Should I have used polarized caps for both? |
First, C1 is for the shorter times and C1+C1x is for the longer times. So you would want C1x to be larger than C1.
What exactly do you mean by running nonstop?
Ian |
furio
furio
Posted: Tue Dec 13, 2011 2:53 am Post subject:
Hi to all!
I have solved the problem, it was the MFB MIDI_2_CV or the Doepfer A-140 ADSR connected on the same Gate BUS. For some strange reason it crashed the gate on this interface
With the A-190-3 USB_2_CV 5V Gate or the MIDIMPLAT 15V Gate by Roman Sowa using C1 470n and C1x 4u7 timing caps works fine for me.
The only problem is a too high CV ground sound with my VCA's using the fastest Attack/Decay. Which is the better way to reduce this glitch/click produced by the envelope output to control a VCA_CV? |
furio
Posted: Thu Dec 15, 2011 10:59 am Post subject:
I would like to apologize to Mr. Fritz be it that I have made a modification that is without any style! I have only followed my own intuition.. and this is the result thereof... seeing that my knowledge of the electronic world is rather limited! This is what I did.
I cut the trace between the potentiometers and C1 and then jumped with a 8K2 resistor. If I should need to modify another envelope, I'll try some lower values.
Now I have one of the four envelopes which I assembled and found it to be compatible to control all my VCA's.
If someone could help, I attached the drawings for the euro modification to the PCB and my euro panel. I have used Musikding's 5x10cm PCB's, 16 HE/TE (8cm) Euro Panel and Lazertran.
507.23 KB |
| Viewed: |
63 Time(s) |
 Download |
| Filename: |
FritzQuadADAR.pdf |
490.8 KB |
| Downloaded: |
106 Time(s) |
frijitz
Audio files: 54
Posted: Thu Dec 15, 2011 2:45 pm Post subject:
| furio wrote: | | I cut the trace between the potentiometers and C1 and then jumped with a 8K2 resistor. |
That's a good idea. The Bridechamber version has 1k resistors in series with each pot. The Elby version has 270R in series with the A pot and 1k in series with the D pot. Using a larger value makes sense for your version with the switched cap.
Ian |
Silesius
Posted: Thu Feb 21, 2013 9:27 am Post subject:
Hi, I'm building a dual AD/AR following Bugbrand layout. I'm testing it and it's working fine. However, I have a question regarding this circuit. I would like to make it retrigger itself, to use it as an LFO as well. My knowledge of electronics is very limited, so I think I'm missing something.
The idea is to use Ken Stone's slope detector circuit. I think that's what I need for the job.
http://www.cgs.synth.net/modules/cgs62_sd.html
I'm using just the fall out portion and it's working nice as well; it outputs a pulse when the envelope falls without problems. Now, I though it would be just a matter of routing this pulse back into the envelope's input, but that's not working. Sometimes everything stops, sometimes it works but very fast, almost in audio range. Too much for using it as LFO...
I know there must be a way for this to work, but I can't see it; any help will be very appreciated.[/img] |
Posted: Thu Feb 21, 2013 1:03 pm Post subject:
If you're retriggering when it *starts* to fall, you never let the "D" portion of the envelope complete before you're retriggering.
You need to set a level below which it retriggers as well, something close to ground. So you need slope detection and also level detection and a way to combine them to generate the trigger.
Not sure HOW you'd do that off the top of my head though. |
frijitz
Audio files: 54
Posted: Thu Feb 21, 2013 1:46 pm Post subject:
| Silesius wrote: | Hi, I'm building a dual AD/AR following Bugbrand layout. I'm testing it and it's working fine. However, I have a question regarding this circuit. I would like to make it retrigger itself, to use it as an LFO as well. My knowledge of electronics is very limited, so I think I'm missing something.
That early design has been supplanted by the 4x4 Envelope Generator:
http://home.comcast.net/~ijfritz/sy_cir12_4x4.htm
You can buy boards or a kit for this from Elby.
I don't know enough about the slope detector to say if it could be made to work as you desire.
Ian |
diablojoy
Joined: Sep 07, 2008 Posts: 730 Location: melbourne australia
Posted: Thu Feb 21, 2013 1:51 pm Post subject:
use a window comparator circuit with upper threshold near zero volts and lower threshold at zero volts
and then 'AND' that with the 'falling' output of the slope detector, the output of the AND gate will only output a signal when both its inputs are high
so you will only get a retrigger when the EG is near to completing its cycle _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
sonicwarrior
Joined: Dec 22, 2005 Posts: 189 Location: Cologne, Germany
Posted: Mon Mar 04, 2013 3:11 pm Post subject:
No documentation? Schematics? |
frijitz
Audio files: 54
Posted: Mon Mar 04, 2013 7:57 pm Post subject:
| sonicwarrior wrote: | | No documentation? Schematics? |
Schematics for all my commercial projects have been taken down because of theft. Operation of all the 4x4 features is in a doc at Elby's:
http://www.elby-designs.com/contents/en-us/ed114-guide.pdf
Ian |
sonicwarrior
Posted: Tue Mar 05, 2013 2:47 pm Post subject:
For Oakley and MOTM modules I get at least the schematics when I order the corresponding boards.  |
frijitz
Audio files: 54
Posted: Wed Mar 06, 2013 8:00 pm Post subject:
| sonicwarrior wrote: | For Oakley and MOTM modules I get at least the schematics when I order the corresponding boards.  |
Has either of them had circuits stolen and used for commercial purposes?
Anyway, I can work with builders on an individual basis, and anyone who is, let's say, a member in good standing around the forums can get circuits for boards they buy.
Ian |
sonicwarrior
Posted: Sun Mar 31, 2013 1:20 pm Post subject:
Oh, I forgot to answer.
I'll finish my two existing original All-In EG first before deciding whether to order the advanced one Elby is offering. |
