 Forum index » Instruments and Equipment » Cubase
Midi Recording Latency
Page 1 of 1 [7 Posts]
petery
PostPosted: Wed Feb 27, 2008 10:50 am    Post subject:  Midi Recording Latency
Subject description: Midi Recording Latency
Hi Everyone,
When I try to record MIDI in real time in my Cubase SX for some reason recorded notes come out delayed by 16th or more... Is it some setting that I need to adjust or there is something wrong with my set up?
I remember I had that problem vith previouse versions of Cubase long time ago and it was just a setting somewhere... I just don't remember where..
Thanks,
Peter
Low Note
PostPosted: Wed Feb 27, 2008 8:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
A little more info on your set up might help.
What hardware are you using. Do you know what latency you have set to?
Do you have any quantizing going on? You might need to adjust the length that it detects.
petery
PostPosted: Wed Feb 27, 2008 8:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm using MIDI Delta Midisport 2x2 for MIDI and Safire Pro for audio... Runing Cubase SX... I do not think I have any quantization going on at record time...
Where do I adjust the detection length?
Thanks,
Peter
Low Note
PostPosted: Thu Feb 28, 2008 4:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I only have SL 3 and its on another computer, but its in the same dropdown menu as VST Instruments. Its called Device Options or Device Setup.
There may also be something to adjust in VST Connections with latency.
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Mon Jul 07, 2008 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
i have the same issue , and different midi interfaces act differently .. like my saffire pro midi places all notes at position 0 after recording.. my edirol um-1 places the notes further ahead.. each time i restart cubase it places the notes on a different position. I've read something about the ignoreportfilter in the cubase folder, this gives you emulated drivers wich might work properly..
longfella
PostPosted: Sat Nov 29, 2008 4:28 pm    Post subject: hi Reply with quote  Mark this post and the followings unread
could be worth swapping the asio drivers around, they all have there own strong and wek areas for various tasks thats why theres more than one on your menu it should tell you howmuch its effected your system latency
ikarus
PostPosted: Sat Jan 14, 2012 4:43 am    Post subject: Re: Midi Recording Latency
this is a well known bug due often to duplicate midi ports ( sx for some reason on some systems creates 2 x of each midi port it detects.....) there is also an issue of the system clock on sx i think ? i went to cubase 5 in the end and dont have these issues ( though i still think c5 is pretty shite as are most steinberg products now and 99% code protection and very unstable in many ways compared to logic but hey....i dont own a mac yet )
