Funky40
G2 patch files: 5
Posted: Thu Mar 06, 2008 9:05 am Post subject:
the Future in Modular:what do you expect, what do you wish ? Subject description: will digital rule some modultypes ? |
just thought i open a thread about the Future and what is to expect or what one would wish.
I kept it open for any kind of module.
please post your thoughts and wishes and expetations
My ones are:
VCOs:
I expect that there will be digital Multioperator FM VCOs.
The Modcan VCDO might be just one Step in that direction and what we can expect ( i never heard the VDCO in real )
What i wish:
digital Multioperator FM VCOs with Thru Zero !
I don't know if thru Zero is needed in digital or if it is possible to implement it,
but thats what i whish to have, and thats what i think it will come,
and thats what i think everybody will going crazy about
LFOs:
I wish to have LFOs with sync to midiclock and analog clocksync maybe too.
and i whis them to as quad modules in digital,
and with CV on clockdivider ratios for each unit.
Maybe switching between waveforms with another CV input
Envelops:
hmmmm, maybe the modcan is it allready.
-----> Decay should have S-mode ! Attack maybe too
__________________________________________________________
VCO comment:
Can you imagine how funny it must be to have multioperator FM, but all with patchpoints ?
We all will turn our Modularsynth into a DX7 .................................
woot, woot :
i'd like to have a DX77-modular |
Posted: Thu Mar 06, 2008 9:17 am Post subject:
Obviously what we are missing right now are more hybrid modules that are partly based on embedded processing. I believed this would happen 10 years ago. I was wrong. Digital-analog hybrid modules with onboard DSPs will eventually be the next big thing. I can easily come up with module ideas, but we will need DSPs no matter what. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
neandrewthal
Posted: Thu Mar 06, 2008 11:19 pm Post subject:
elektro80 wrote: | Obviously what we are missing right now are more hybrid modules that are partly based on embedded processing. |
I'll make some. Umm........check back with me in 7 years. _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
Kwote
Funky40
G2 patch files: 5
Posted: Fri Mar 07, 2008 1:03 pm Post subject:
elektro80 wrote: | Digital-analog hybrid modules with onboard DSPs will eventually be the next big thing. |
Yes, my thinking too.
Modcan has modules with DSPs.
http://www.modcan.com/bseries/modulesb.html
---> 57B, 58B,59B,60B
I think modcan is opening the minds for that kind of modules.
Has it been doepfer coming first with that stuff, maybe many folks would not accept it.
but modcan......................?
btw.: for me it seems that the VCDO is one of the best Value for Price VCOs available now. |
cbm
Joined: Oct 25, 2005 Posts: 381 Location: San Francisco
Posted: Sun Mar 09, 2008 2:08 am Post subject:
The Buchla 200e series is basically like this. Every module has a processor, and various amounts of analog circuitry around it.
Some modules use the CPU for control only, some modules use the CPU for DSP. |
dougcl
Posted: Mon Mar 10, 2008 8:20 pm Post subject:
I would rather see the digital processing stay out of analog modulars. I think we should go the other way and use tubes, mechanical devices, tin cans and string. Leave digital in separate systems on the other side of D/A converters.
Doug |
Kwote
Posted: Tue Mar 11, 2008 3:05 pm Post subject:
dougcl wrote: | I would rather see the digital processing stay out of analog modulars. I think we should go the other way and use tubes, mechanical devices, tin cans and string. Leave digital in separate systems on the other side of D/A converters.
Doug |
i think digital has it's place in the realm of control. not so much beyond that. and i think dsp's, menus, lack of knobs is exactly why i avoid non modular gear.
so it's kinda weird seeing this digital modular revolution. however i think it's okay for it to exist.
i just don't plan on being a part of all that for the most part. like i said there is a place in it for my applications. but not a big place.
i have a ton of analog experiments to do. i've found that most basic components of analog modulars have endless potential and with enough time and creativity a ton can be accomplished.
i think i'm wrapping my head around everyone's lust for this new development though. in a field where people just can't stop building and acquiring more gear, it makes sense that people would come up with anything and everything they can to keep expanding.
i personally thrive on limitation. or what i'd prefer to call so-called limitation.
right on Doug. _________________ http://www.kwotemusic.com
My EP's for sale:
http://www.kwotemusic.com/store.html
Check out a preview:
http://www.kwotemusic.com/JourneyToSomewherePreview.mp3 |
cbm
Posted: Tue Mar 11, 2008 3:25 pm Post subject:
Well, in the case of the Buchla most of the use of digital electronics is in the control world, but there is a little use in the DSP arena, as well.
For example the 261e oscillator generates sine waves digitally, but does all the waveshaping with digitally controlled analog circuitry.
For me, modular synthesis is about how you interact with a system: patching and knobs. How things are implemented under the surface is less interesting. To the extent that the Buchla 200e is all knob and patching based it's great. Where is starts to be less fun is on the (very few) modules that require more detailed programming (mostly the 291e filter, and the discontinued 249e sequencer) |
Keysandslots
Joined: Aug 18, 2006 Posts: 266 Location: Mississauga, Ontario
Posted: Tue Mar 11, 2008 5:20 pm Post subject:
The only "modular" I have is a Nord G2X and I've figured out that while I'm smart-enough to work every other synthesizer I've ever tried, this modular stuff is a bit beyond me so far. I'm also realizing I'm kinda lazy, and a bit pre-occupied with too many other things. But, I really like the various incredible sounds that come out of the Nord.
So, here's what I'd like to see, and this is probably possible with something like the Nord. I want to fill out a sort of music/personality test, almost like a Myers Briggs sort of thing, where I answer specific questions about my personality, the sort of sounds I like, the kinds of music I play and listen to and other characteristics. Then, I want the computer/synthesizer to take that information and make some first cut "patches" for me, and perhaps some suggestions for further experimentation, in effect teaching me to use the synth. Depending on my personality (do I like to go off on tangents sometimes for example), maybe it could hit me with the odd surprise patch.
This is kinda broad-brush and not very thought-out but it's just a thought at the moment.
Randy |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Wed Mar 12, 2008 8:06 am Post subject:
Harmonic vco like in the oscar. |
williamsharkey
Posted: Wed Mar 12, 2008 8:20 am Post subject:
Equasion Solver Module:
A small monitor with a small keyboard and 3 A/D inputs and 3 D/A outputs.
You type an equasion, like: 0ut1=In1*In2
So you have just created a ringmod.
But you could create many different modules by typing in different equations.
( PS I have created a VST prototype called MusicComputer that does this. It's still in testing/patching stage.) Last edited by williamsharkey on Wed Mar 12, 2008 8:36 am; edited 1 time in total |
williamsharkey
Posted: Wed Mar 12, 2008 8:34 am Post subject:
My response is off topic, sorry: Keysandslots wrote: | Then, I want the computer/synthesizer to take that information and make some first cut "patches" for mey |
If you took a synthesizer with a "randomize patch" function, and rated your reactions to 100's of randomized patches, you could then use a data-mining technique to find relationships between patch parameters and reaction.
You would answer questions like: rate the "beauty" of this sound on a scale 1 to 10. or rate the "purple-ness" or rate the "musicality" or the "shimmer".
If the data-mining is successful, then you could use the process in reverse. You tell the program how "beautiful", "purple", "musical" and "shimmiring" your sound should by sliding a slider or what not. Then it generates the patch parameters.
http://en.wikipedia.org/wiki/Data_mining
(Would have done this myself but I haven't found any data mining software that I could learn yet) |
GovernorSilver
Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
Posted: Wed Mar 12, 2008 11:02 pm Post subject:
Keysandslots wrote: | The only "modular" I have is a Nord G2X and I've figured out that while I'm smart-enough to work every other synthesizer I've ever tried, this modular stuff is a bit beyond me so far. I'm also realizing I'm kinda lazy, and a bit pre-occupied with too many other things. But, I really like the various incredible sounds that come out of the Nord.
Randy |
You could also take the G2 patch archive, along with the 20k patches for the nm1 (converted to your g2), and start messing with the Patch Mutator in the editor. That's a few weekends at least (or, it was for me |
Funky40
G2 patch files: 5
Posted: Thu Mar 13, 2008 7:41 am Post subject:
cbm wrote: | For me, modular synthesis is about how you interact with a system: patching and knobs. |
Thats exactly how i see it too. |
Posted: Thu Mar 13, 2008 7:58 am Post subject:
Funky40 wrote: | cbm wrote: | For me, modular synthesis is about how you interact with a system: patching and knobs. |
Give me that paper and I´ll sign it too.
We call them analogue modular synths because the interesting hybrid modules haven´t really showed up yet. I´m sure they will and there will be plenty too. It might take another 10 years though. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
cbm
Posted: Thu Mar 13, 2008 10:03 am Post subject:
elektro80 wrote: | We call them analogue modular synths because the interesting hybrid modules haven´t really showed up yet. I´m sure they will and there will be plenty too. It might take another 10 years though. |
I think that the future is here already, just not evenly distrubuted. Examples:
Most of the Buchla 200e
A handful of Modcan modules (VDCO, CV Recorder, Quad Env, etc.)
A handful of Plan-B modules (tap clock, more to come)
All of the Harvestman modules
A handful of Doepfer modules
Analog Systems Harmonic Generator
Encore UEG
And I'm sure there are more that I'm forgetting
I think the days of modular synthesizer == analog synthesizer are over.
The days of modular synthesizer being fun to use are still here, thankfully.
-C
Kwote
Kwote
cbm
Posted: Fri Mar 14, 2008 2:40 pm Post subject:
Kwote wrote: | cbm wrote: | I think the days of modular synthesizer == analog synthesizer are over. |
disagree. i think they're still in their hayday. i'm gonna enjoy it while it lasts. |
Oh, I agree that this is still an era of analogy goodness, I was just saying that modular doesn't automatically mean analog anymore. To keep with the equation theme: modular synthesizer >= analog synthesizer. Better? |
Funky40
G2 patch files: 5
Posted: Fri Mar 14, 2008 8:14 pm Post subject:
I call it Hardware modular vs. software Modular, not digital vs. analog.
Clavia NM1 and G2 belongs then to the Software modular (for me).
Yeah, the analog world was never more interesting then now, i think. |
cbm
Posted: Fri Mar 14, 2008 11:11 pm Post subject:
Funky40 wrote: | I call it Hardware modular vs. software Modular, not digital vs. analog. |
The modules I mentioned a few posts back are physical modules that will fit into existing modular systems.
I don't think that they fit too well into your categories. They are digital modules, in a hardware modular.
-C
Kwote
Posted: Mon Mar 17, 2008 3:37 pm Post subject:
cbm wrote: | Kwote wrote: | cbm wrote: | I think the days of modular synthesizer == analog synthesizer are over. |
makes sense. thought this discussion pertained to hardware analog/digital only.
but i'll definately not hesitate in saying i don't have a single bit of interest in software synthesis, effects, etc.
even with recording, if i could afford it, i'd go to tape. but for now i'm living with CEP 2 basic tracking purposes only. _________________ http://www.kwotemusic.com
My EP's for sale:
Posted: Mon Mar 17, 2008 9:06 pm Post subject:
Kwote wrote: | ...but for now i'm living with CEP 2 basic tracking purposes only. |
That'sstill the best thing out there! "living" is the high life! |
