OSC from java
Page 1 of 1 [3 Posts]
Audio files: 211
G2 patch files: 92
PostPosted: Sun Mar 09, 2008 12:13 pm    Post subject: OSC from java
Subject description: Just send so far
I did this monome clock app for fun, and figured that someone might be interested in (or want to comment on) the code for sending OSC commands from Java. I put all of that code in the OscCommunication class.
/Stefan
monome-clock.zip
 Filename:  monome-clock.zip
 Filesize:  9.15 KB
 Downloaded:  96 Time(s)
PostPosted: Sun Mar 09, 2008 9:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool. I'll have to try & play with it. I'd like to learn more about OSC, I haven't had a real application for it (yet), but can invision some things I'd like to try. Where did you start learning it? ANy good tutorials you came across? There seems to be some very in depth material regarding how things work, but I haven't seem much in terms of *use* or implementation (programming code, or programming an instrument).
Audio files: 211
G2 patch files: 92
PostPosted: Mon Mar 10, 2008 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I learned by looking at code examples bundled with ChucK, and a spec like this: http://archive.cnmat.berkeley.edu/OpenSoundControl/OSC-spec.html
I haven't looked at #bundle or the pattern matching stuff on the receiving end, or other OSC implementations than the one in MonomeSerial, but it looks like a pretty thin protocol with a lot of freedom in how you layout your commands and arguments. The only tricky part in sending via a UDP API was aligning the bytes. It would be interesting to see a well-tested OSC protocol for a tone generator or something.
Other than the monome, I only know of pure software applications using OSC - see the wikipedia page here: http://en.wikipedia.org/wiki/OpenSound_Control
/Stefan
Niio1
