 Forum index » Clavia Nord Modular » G2 Patches - Completed » Pad
Heavily bowed string ensemble patch
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Thu Jun 17, 2004 3:45 pm    Post subject: Heavily bowed string ensemble patch Reply with quote  Mark this post and the followings unread
For a change, it's not based on FM Smile
This one came from one of those 'accidents'. I was starting a speech patch and had a sawtooth osc and noise source cross fading with an envelope. It sounded a lot like bowed strings so I developed it into this patch. A 'trick' worth noting is the use of the EQ/Mix2-1B modules. The EQ module provides a boost/cut control, if you want to remove all the frequencies outside the boost area, mix the output 1:1 with inverted copy of the input (no sound is output at all if response is set flat). The three EQ's are supposed to simulate multiple body resonances. That suggestion came from Gino Vannelli's brother in a Contemporary Keyboard interview.
I have put it in the PAD category, though only variation 8 is strictly Pad like.
stringsarc3.pch2
Bowed String Ens
 Filename:  stringsarc3.pch2
 Filesize:  3.08 KB
 Downloaded:  2264 Time(s)
