How can i keep this from clipping?
Page 1 of 1 [8 Posts]
wppk
PostPosted: Tue Mar 18, 2008 12:33 pm    Post subject: How can i keep this from clipping? Reply with quote  Mark this post and the followings unread
Crying or Very sad it seems that everytime 1000::ms passes it sums the new pass to the old and therefore it eventually clips. Any idea how to prevent this?
[code]fun void solarwind() {
while(true){
BPF b => HalfRect r => LPF l2 => JCRev rev => Dyno limiter => dac;
Noise n2 => b;
//tried overall gain
1.0 => dac.gain;
n2.gain(.1);
//tried limiter but not sure exactly how to set this one
limiter.gain(.95);
//what argument type is used for .limit
limiter.limit();
rev.mix(.1);
b.Q(10);
b.freq(5000);
l2.freq(Std.rand2(500,100));
l2.Q(Std.rand2(50,1000));
1000::ms => now;
spork ~ solarwind();
while(true){100::ms => now;}
kijjaz
PostPosted: Tue Mar 18, 2008 6:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've tried messing around with the patch..
but I suspected that the thing that causes this clipping character..
are those Qs in BPF and LPF -_-"
How about trying other kinds of more basic filters and see?
wppk
PostPosted: Tue Mar 18, 2008 9:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not so sure. it seems that even without the Qs the loop just keeps getting louder every time 1000::ms passes. It's kind of like feedback. I'm baffled.
Thanks for having a look Kijjaz. By the way, what type of argument does the .limit member take? doesn't seem to like float or int.
kijjaz
PostPosted: Tue Mar 18, 2008 9:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
liimt() is just a function to load a preset.
it sets various values.. see http://chuck.cs.princeton.edu/doc/program/ugen_full.html#Dyno
HEY...! ..
I thought HalfRect is always absolute, and the value of l2 might be building up..
hmmm.. but it didn't.
ok let me see more...
ahh...
OH!
HEY...
Hahhahahha oooohhhhh oh..... I know -_-"
You see the BPF b => HalfRect r => LPF l2 => JCRev rev => Dyno limiter => dac; and also the Noise?
that's in the while loop..
so every time it run in there,
there's a brand new instant of that whole row of UGens.
So those all adds up to DAC.
also all the values of the limiters are added to dac, so the values are added up.
here's a fix i made:
Code:
Noise n2 => BPF b => HalfRect r => LPF l2 => JCRev rev => Dyno limiter => dac;
    1.0 => dac.gain;
    n2.gain(.1);
    limiter.gain(.95);
    limiter.limit();
    rev.mix(0.5);
    b.Q(10);
    b.freq(5000);
while(true){
    1000::ms => now;
Another example: (very psychedelic indeed)
Code:
limiter.limit();
limiter.thresh(.8);
limiter.ratio(10000);
while(true)
    // new SinOsc instants will build up in memory each time this is run.
    SinOsc s => limiter;
    .2 => s.gain;
    Std.rand2f(0, 127) => Std.mtof => s.freq;
    500::ms => now;
warning!! not good for memory! hahahh -_-
PostPosted: Wed Mar 19, 2008 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I think you may need it move the definitions of the Ugens out of the "while" loop (so above it). I think that right now it keeps re-defining Ugens.
while(!machine.crash() ) <<<"all is well">>>;
Audio files: 6
G2 patch files: 48
PostPosted: Wed Mar 19, 2008 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Wait a minute! That means that code like this:
Code:
1 => int tjohej;
while (tjohej) {
        SinOsc s => dac;
        1::second => now;
        0 => tjohej;
while(true) {
        1::second => now;
will leave a tone ringing with no possibility to turn it off, right? Hmm...
/Stefan
You are Wendy Mackaye, first girl on the red planet.
wppk
PostPosted: Thu Mar 20, 2008 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Right. Duh. Thanks Guys.
PostPosted: Fri Mar 21, 2008 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Kinda.
If you feel the urgent need you can in fact shoot yourself in the foot.
Still, I think the tone will stop if you exit the shred so I don't think it's a really big deal.
Once You Know, You Newegg
