Newbe Question on Wavefile Cleanup
Page 1 of 1 [8 Posts]
Mr Theremin
PostPosted: Wed Mar 26, 2008 12:43 pm    Post subject: Newbe Question on Wavefile Cleanup
Subject description: Cleanup wave file buffer
I’m trying to code up a sampler in chuck in WinXP. This project may be too challenging for a beginner but I want to discover ChucK’s qualities and problems quickly so I jumped in with both feet.
What I am trying to understand is how to clean up after SndBuf.
I have been watching the Task Manager and it seems that memory and CPU are never released. I have tried several different methods of starting and sporking. The wave files here are any large sample (so that you can see memory usage meter move). Every instance of this code will grab more memory and not release until the main task is killed. Does any one know why this would leak the memory?
Is there a simple way to unload the file "FileName.wav" =< buf.read; ?
Code:
// spork the test function, store the shred reference
spork ~ Play() @=> Shred @ s;
3::second => now;
// remove by id
Machine.remove( s.id() );
3::second => now;
// test function
fun void Play()
SndBuf buf1;
"Large.wav" => buf1.read;
buf1 => dac;
SndBuf buf2;
"Large.wav" => buf2.read;
buf2 => dac;
SndBuf buf3;
"Large.wav" => buf3.read;
buf3 => dac;
3::second => now;
[/code]
Frostburn
PostPosted: Wed Mar 26, 2008 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Garbage collection is one of the lacking features in ChucK at the moment.
If memory taken it is usually not released.
I ran a quick test and it seems that you can manually release the memory SndBuf uses by loading up an empty sound file to it. (Hopefully it also work in Windows. Linux here.)
EDIT: Oh and welcome to the board!
Theremins rock.
In Serendipity We Trust
Mr Theremin
PostPosted: Wed Mar 26, 2008 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow Frostburn, thanks for a speedy reply... with an experiment included no less. You guys rock. Your idea will make a fine workaround until something gets revised.
Now if I could only figure out how to display this cool avatar image I found of Léon Theremin playing his early instrument. I uploaded it to the profile page but I don’t see it on my message.
Audio files: 17
G2 patch files: 277
PostPosted: Wed Mar 26, 2008 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe it's too large?
Mr Theremin
PostPosted: Wed Mar 26, 2008 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, my image is only 6K. I'm testing one more time with a different image. If this doesn't work it must be me and I'll stop cluttering this wonderful forum with my void messages.
Inventor
Audio files: 37
PostPosted: Wed Mar 26, 2008 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Post with reckless abandon! You should see some of the thinking out loud nonsense I post sometimes, I bet folks get a good laugh from time to time.
@(ºoº)@ ><}}}º> ~(^.^) <:3 )~
Audio files: 17
G2 patch files: 277
PostPosted: Wed Mar 26, 2008 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, so it's probably smaller than 100x100 pixels as well ... weird ... I checked your profile, nothing indeed ... maybe try to upload the image here or PM it to me so I can try to get it into your profile.
PostPosted: Wed Mar 26, 2008 6:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, just start typing and see where you end up, that's the ChucKian way!
while(!machine.crash() ) <<<"all is well">>>;
