benway
Posted: Thu Mar 27, 2008 2:05 am Post subject:
micro modular not working with new nomad Subject description: no connection |
Hi there,
i was very happy when i see the new version....
I use a apple powerbook PPC and Mac Os X 10.4.11 RMe Hammerfall DSP but i get no connection to my micro modular. I do everything as you descripe it and under the editor of clavia everything works fine. So no connection mistake. I copy all and everything.
In the videos everything is very fine descriped but when i hit the button i get no connection to my micro modular. i also get no connection when i go over the menu just nord modular is shown but the editor don't show me nothing which is in my micro. I'm also not able to change something in the conection settings or settings. I also look at the other pages here where people have problems....but i was not able to fix it like they (mostley) do.
i really love your work. So what shall i do?
this may be intressting for you....
java.lang.NullPointerException
at net.sf.nmedit.jsynth.midi.MidiDescription.<init>(MidiDescription.java:26)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog.applyPortSettings(SynthPropertiesDialog.java:244)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog$MyAction.run(SynthPropertiesDialog.java:223)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:180)
at java.awt.Dialog$1.run(Dialog.java:535)
at java.awt.Dialog$2.run(Dialog.java:563)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Dialog.show(Dialog.java:561)
at java.awt.Component.show(Component.java:1302)
at java.awt.Component.setVisible(Component.java:1255)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.showSettings(SynthObjectForm.java:1257)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:947)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110) |
julien
benway
Posted: Thu Mar 27, 2008 4:35 am Post subject:
My God!
At first i install plumbstone and it didn't work.
Then i install mjj and it didn't work.
Then i install your files which comes with the installer and install mjj.
Now IT WOrkS !
I can't belive it!
Maybe you should write in your documentation that you have to install your files and mmj
You guys are so fucking cool
You save My Micro
God bless you for the rest of your life
mercu80
Posted: Fri Sep 11, 2009 11:16 am Post subject:
hi, i'm planning to buy a micro modular and ust it with my powerbook PPC osx 10,4.....which midi card do you suggest?
thanx
mat |
