 Forum index » Instruments and Equipment » MAX/MSP - Pd
Max/MSP Trouble
Page 1 of 1 [6 Posts]
Porkchop
PostPosted: Tue Apr 08, 2008 5:30 pm    Post subject: Max/MSP Trouble Reply with quote  Mark this post and the followings unread
Hey, I'm building my own performance environment in Max/MSP, and I'm currently having trouble using effects.
Basically I'd like to use MSP effects like overdrive~ and cascade~ with a MIDI sequencer that I've built. I can't figure out how I can get the midi signals to work withthe MSP objects.
Does anyone know how to do this? Or even if it's possible?
Thanks in advance.
cbm
PostPosted: Tue Apr 08, 2008 6:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
First off, this message should probably be in the Max forum:
Forum index » Instruments and Equipment » MAX/MSP - PD
Second, what do you want your MIDI signals to control. It's pretty easy to use a MIDI controller to control overdrive amount or eq or other things like that. What specifically do you want to do?
-Chris
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
Porkchop
PostPosted: Tue Apr 08, 2008 7:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah ok sorry about that.
Ok, I should perhaps rephrase. I want the effects to be added to the midi sound- i.e. I have 3 multisliders giving the pitch, velocity and duration linked to a tempo object and a counter, thereby giving a basic sequencer. I would like the effects to be added to the final sound made my this sequencer.
cbm
PostPosted: Tue Apr 08, 2008 9:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
So what is actually making the sound? The obvious possibilities include an external synthesizer, the operating system's DLS synthesizer, a VST, or generated with MSP?
-C
Chris Muir
Porkchop
PostPosted: Tue Apr 08, 2008 10:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's the DLS. Sorry, shoulda said before, I'm kinda new at this :/
cbm
PostPosted: Tue Apr 08, 2008 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unless you have some way to bring that audio back into Max, there's not much you can do. There is at least a reverb message to the DLS synth, that is documented in the Messages to Max chapter of the Max Topics manual.
Depending on your platform, there are a few ways to approach looping the DLS synth audio back into Max.
Chris Muir
