  Various Artists June Solstice live streaming concert
 Forum index » Instruments and Equipment » OSX as a music workstation
Best way to sinc 2 comp's running Logic
Page 1 of 1 [9 Posts]
ar2jr
PostPosted: Mon Apr 21, 2008 11:44 pm    Post subject: Best way to sinc 2 comp's running Logic Reply with quote  Mark this post and the followings unread
Ok. What do you guys think is the best way to sinc up two computers running Logic 8 and abelton. One computer (macbook pro) is being used as the master sequencer (and no audio) while the desktop g5 is handling all audio (and sample editing, dumping ...). I'm thinking midi is the way to go. Any experience and suggestions are much appreciated.
-matia
PostPosted: Tue Apr 22, 2008 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
OS X has a built in midi over ethernet pipe. Theoretically you should be able to send midi from the Mac Pro to the G5 using ethernet. Unless you have silly amounts of traffic on your lan this should work OK. I dunno how to sync Abletone Live to midi using the OSX supplied ethernet pipe though. I have never tested that config.
Flickr
ar2jr
PostPosted: Tue Apr 22, 2008 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
well live would run in rewire slave mode so the midi over ethernet should be fine to get logic rolling (which will hit live). then it's a matter of configuring the master and slave computers.
PostPosted: Tue Apr 22, 2008 3:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool.
BTW, use a gigabit switch of decent quality. You might even look into using Logic Node on that G5.
Flickr
ar2jr
PostPosted: Tue Apr 22, 2008 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
well ... so here's a bit of IMPORTANT FUCKING INFORMATION I didn't know. In logic 8 apple removed the ability to sinc to external MIDI Clock. I use to do this with Logic 7 no problem and now I can't. What the fuck?!? I want one computer to be the master and the other to use the same application because that's what I paid for and what I use god dammit!! My band has two copies of logic 8 so why the fuck can't i run them in sinc at the same fucking time...
-matia
ar2jr
dbl post
CJ Miller
PostPosted: Sat May 03, 2008 10:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ouch! I didn't know that it external sync was gone (using v7.2). I'd complain to Apple in a civil but emphatic way. If this basic functionality is missing then they should restore it in an update.
PostPosted: Sun May 04, 2008 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Logic can still act like Master. I guess they ditched slave mode and instead they threw in the Logic Node features. It´s the Midi Beat Clock - slave mode that is gone. The old MTC is still in there though, but I guess that won´t help you much. Sad
Flickr
ar2jr
PostPosted: Fri May 30, 2008 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
well ... i get about 3 to 6 ms of lag synching via MTC over Ethernet. In theory if everything is compensated for this should be cool to go with the original plan I had of having one comp be the sequencer and the other a 'tape machine'/sample editor ... in any case the major downside to this is that you basically have to forget about tempo automation unless you want to set up some kind of common file that you automate in and then transfer to the other computer ... MTC will start and stop and make both machines follow but, you still have to manually set the tempo for the salve computer ... this is a major drag and just adds more to the tech shit that needs to happen before doing anything ... but ... it seems to hold the tempo well when slaved. we ran something like ten to fifteen minutes of midi via ethernet and noticed no wavering in the tempo so it's only the ms delay we have to compensate for ...
I'll post more results in terms of how well all of this works once everything has been as streamlined as possible.
-matia (who is finally on holiday after enduring much pain, suffering, and torture by academic forces that be)
