CEM3394 modular schematic
Page 2 of 2 [36 Posts]
Goto page: Previous 1, 2
PostPosted: Fri Apr 29, 2011 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
oops.
alas, i don't even have a 3394 Wink
so you don't want to help because they don't understand the datasheet? or because they ask the wrong questions? advice to RTFM or refering to a products page only doesn't help much IMHO. but thank you for the link anyways.
fonitronik at
PostPosted: Fri Apr 29, 2011 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
again, i don't have a CEM3394. who cares?
i have a question in regards to the VCO section as described in the datasheet (maybe i am just dumb, but i want to learn, so...):
the datasheet states a min/max range of the CV input of -4V to +4V, and the IC is normally powered from +5V / -6.5V. shouldn't the CV input be protected against higher control voltages? all the more as the LM324 is able to swing close to the rails? i don't see this on the cram or ele4music schematic.
fonitronik at
bod
PostPosted: Tue Jun 28, 2011 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik, i've been thinking about this as well as i have a few spare of these chips that i bought to do up an old sixtrak, and fancied doing something with them.
i was just going to make a non patchable keyboard synth with everything running off +5v and -6.5v, but figured it would be nice to include CV sockets for external patching to other things. if we asume that the we are using "standard" +/-5v CV's, then i was thinking an opamp to divide the voltage down to +/-4v would suffice with a zener diode to protect the 3394 from any voltages above the chips supply level of 5v, however i'm not sure how to handle the negative voltages just yet. obviously the opamps would need to be powered from +/-12v or +/-15v in order to handle anything that is pumped into it from an external source.
I havent had chance to poke around in the dark star from doepfer, but they must incorporate something similar with the cv inputs on the unit.
anyway, i'd obviously need to ensure the circuit works and adhere to the specs int he data sheet to make sure i A) dont fry the chip and B) dont fry someones patience from earlier.... Wink
PostPosted: Tue Jun 28, 2011 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
1st i would assume keyboard CV's from 0-10V. however, it is all about range anyways. if you have keyboard voltages you would have to turn down your inital freq knob to get the full range, for +/-5V you would have to turn it up (offset).
in tom gamble's schematic you have an additional range trimmer for that IMHO this is redundant (see aaron cram schematic).
why +/-12v or +/-15v? if i read the datasheet correct, a LM324 can handle +/-16V on its inputs even when powered from +5V/-6.5V. this is actually exactly what aaron cram shows.
anyways, i would have thought that we need some kind of protection for the CEM IC.
opinions?
fonitronik at
bod
PostPosted: Tue Jun 28, 2011 3:13 am    Post subject: Reply with quote  Mark this post and the followings unread
the keyboard circuit i have at the moment is an arduino based system i built using a 3 oct keyboard, and the cv out only spans 0-5v. so that should be fine for this purpose.
i wasnt aware the 324 could handle such voltages even when powered from +5 and -6.5V. nifty wee chip! i'm stuck in the MCU thinking of anything over its supply will kill the chip. obviously not with the 324!
so that leaves over voltage protection.... i'm looking through a few articles and data sheets for various things to see what i can come up with....
PostPosted: Tue Jun 28, 2011 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
i just read on the national semi site:
Differential input voltage range equal to the power supply voltage
so we would need additional input protection for the opamp as well!?
fonitronik at
bod
PostPosted: Tue Jun 28, 2011 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
ah, well id be tempted to go back to the +/-12v supply for the op amps with over protection on the 3394 inputs then.
having said that, all i can find are the usual diode tricks that only help with positive voltages, and a few exotic solutions from analogue devices that look a little over the top.
Ricko
PostPosted: Thu Jun 30, 2011 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Couldn't you just put /3 voltage dividers on the CV inputs and then it would fit in happily with voltages produced by +/-15V systems without worrying about over-voltages? (VCO F and VCF F excepting of course)
Same thing with PICs too I suppose.
bod
PostPosted: Sat Jul 02, 2011 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd thought about something similar with +/-12v systems but in that situation, a 10v peak to peak lfo becomes 3.3volts peak to peak (if you divide by 3), which limits the range of the sweep and doesn't give you the full effect.
Even though, you can still get a scaled response from the vco and vcf with trimmers on the inputs.
I've got one wired up to an arduino with the cv's coming from the pwm with a low pass filter and a buffer. Despite the low resolution from the pwm, it works a treat! I'll try out some 12 bit dacs i have shortly, however the keyboard controller needs a few tweaks. But, I'm still torn with adding external cv inputs, I just don't want to limit them and/or fry it! Wink
Ricko
PostPosted: Mon Jul 04, 2011 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
well, if you are using 12V put in a 40% voltage divider to get down to 5V.
Paradigm X
PostPosted: Mon Jan 07, 2013 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hullo!
Interesting thread
Did anyone ever get anywhere with this?
Ive picked up an Akai ax73 which i love, but the one parameter editing is a nightmare.
Id love to be able to control at least the vcf and resonance via a pot... any ideas?
I found the data sheet but cant find the ax73 service manual.
This does look promising but i really dont want to break my synth...
Im guessing id need to add the cvs coming from my akai to a fixed cv made by wiring a pot over the PSU but not sure...
Many thanks, Ben
 Filesize:  130.35 KB
 Viewed:  24 Time(s)
Niio1
