Midi zone bug
Rivelen
G2 patch files: 12
PostPosted: Thu May 15, 2008 3:24 am    Post subject: Midi zone bug
Subject description: something causing a G2 system crash
Something is going wrong with the midi zone module :
I use it to simulate the hold chord system of the OB8 : i send a copy of the keyb notes to the slot used by the patch, i can then trig chords or unison with one key, it sound nice and it's DSP friendly, i like it.
The problem is when you switch the channel source of the midizone, from keyb to "this", and play some notes; it cause some weird things :
first, the note off seem to not work anymore, notes stay held.
if you play furthermore with the chan setting while playing, it cause a system crash, the G2 is frozen, you have to restart it...
I known that it's not a critical problem but i submit it anyway Rolling Eyes
(example patch attached, load in slot B)
Another point about that module :
When you change the "trans" value, it don't fire the note off for the previous note. maybe it's not supposed to but i think it would be cool if it does.
bug midi zone.pch2
Load it in slot B
 Filename:  bug midi zone.pch2
 Filesize:  1.85 KB
 Downloaded:  566 Time(s)
