New sequencer project - Documentation on First Page
Page 31 of 31 [761 Posts]
Goto page: Previous 1, 2, 3, ..., 29, 30, 31
LetterBeacon
PostPosted: Mon Mar 11, 2013 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be up for a board!
emdot_ambient
PostPosted: Tue Mar 12, 2013 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, definitely should be a good market for a new version!
Luka
PostPosted: Wed Mar 13, 2013 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
amazing - count me in for switches + pcb
problemchild
melbourne australia
oldbob
PostPosted: Thu Mar 14, 2013 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Count me in for PCB, thanks.
oldbob
So many modules, so little time.
wmonk
Audio files: 12
PostPosted: Sun Mar 17, 2013 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I finally got around building mine, and after a lot of wiring (yuck, those switches o_O) it basically works.
Although.... my CV output gives a nice and steady -13.92V. (Indeed /the/ typical value of a TL074 clipping.)
I would like to fix this of course. What I already checked: voltage on potentiometer wiper is okay. Voltage on the PCVS bus is okay.
Voltage on the PORT1 pin is -13.92V. (again that magical number).
So, what should I do to fix this?
Woody
Edit: forgot to mention that I'm using V2.0 firmware.
Weblog!
Kits for synthesiser modules in Europe
ryktnk
PostPosted: Sun Mar 17, 2013 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Oh dear, that sounds a bit strange.
Please check there are no shorts around the TL704.
PORT1,2 just feed the big capacitor that hangs on an input
of the TL704 [simple lag circuit] so have a look
at the big cap for any shorts [sorry I haven't go my circuit with me
so can't tell you the part no.s at the moment Embarassed ]
I am away on business this week, so cant check my
circuits this week.
I will try and work out some help when I am back next week, sorry.
-ryk
emdot_ambient
PostPosted: Wed Mar 20, 2013 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
circuits this week.
That's what DropBox is for Mr. Green
wmonk
Audio files: 12
PostPosted: Wed Mar 20, 2013 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, replacing the opamp fixed the problem. Very Happy
I now have it working and I love it! One problem still exists, whenever I turn a stage to three steps, it skips the whole stage it altogether.
Woody
Weblog!
ryktnk
PostPosted: Tue Mar 26, 2013 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Woody
Hello
Sorry for the delay - back on dry land !
Glad the CV problem is fixed.
The stage count problem, sounds a little strange.
Can you check the voltage on the CT [stage count] bus.
It is pin 18 of the PIC chip, or from the CT pad on the PCB.
If you stop the clock on the seq, and then push the PREV button
to get to stage "1"
Adjust the Stage Count for stage "1' and check the CT voltage:-
Use a DVM to check the CT voltage [pin 18 of PIC].
It should read 0V if the stage is set to "1" count
and approximately
0.8V for "2" count
1.4V for "3" count
2V for "4" count
2.6V for "5" count
3.2V for "6" count
3.8V for "7" count
4.6V for "8" count
Perhaps also check the stage Mode MD voltage [pin 19 of PIC, of MD pad on PCB]
Adjust the Stage Mode for stage "1", and check the voltage for each setting.
0V for "-"
1.8V for "1"
3.1V for "11"
4.5V for "1-"
Also double check carefully there are no shorts on the PCB
between any of the PIC chip pins, and make sure that MD, CT,MAX
MODE,SDIV wires from the switches and pots are wired to their
corresponding pads on the PCB.
Lastly, it might be worth checking all the diodes from the
POT1-8 bus, to make sure their polarity is correct.
Please refer to the Panel Wiring PDF on the first page of this thread.
Let me know how you get on.
-ryk
panda30y
PostPosted: Fri Apr 05, 2013 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
If you do another run, I'd be interested in 2 or 3 board and switch sets.
synchromesh
PostPosted: Wed May 01, 2013 9:30 am    Post subject: Yes please! Reply with quote  Mark this post and the followings unread
Hi, I'd be keen on a couple of PCBs & PICs myself, once version 3 is ready. This seems like a highly-regarded sequencer module, and I think it would be great.
Thanks very much for putting this together!
