M185 sequencer Project - Software Update !!
Page 35 of 38 [931 Posts]
Goto page: Previous 1, 2, 3, ..., 33, 34, 35, 36, 37, 38 Next
ryktnk
PostPosted: Tue Nov 21, 2017 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
LektroiD wrote:
Any chance of another run of this? Be interesting to see a Eurorack version...
Hello
I can make another run of PCBs, if people are serious and want them.
But they 8 way switches are no longer available to me, so you
will have to make the module with potentiometers instead [which
is easy to build, but they wont have click stops for each setting
so you will have to mark the panel carefully].
If people want to PM me with serious orders, when there is enough interest then
I can order some more PCBs
-ryk
Rvlt
PostPosted: Tue Nov 21, 2017 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Great news! Will PM you later.
One question: does the firmware need to be altered to work with potentiometers or is is the same (so I could still use e.g. 8-way rotary switches)?
thanks!
ryktnk
PostPosted: Tue Nov 21, 2017 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks!
Hello
No it uses the same firmware.
The 8-way switches are wired with resistors to create a stepped
voltage divider, the potentiometers work as a variable voltage
divider, but not stepped.
-ryk
Audio files: 131
PostPosted: Tue Nov 21, 2017 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
cool Smile , i use mine a lot , id be interested to get a couple more if there was another run.
the blue one built a while back, below Smile
 Filesize:  1.08 MB
 Viewed:  48 Time(s)
epicyclus@skrogmusic.plus.com
slo
PostPosted: Tue Nov 21, 2017 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great news for the people who want this seq. I just finished mine, been on the bench quite awhile but I wanted to get it right. Added the portamento switches per stage and it all works nicely.
 Filesize:  1.52 MB
 Viewed:  73 Time(s)
LektroiD
PostPosted: Thu Nov 23, 2017 6:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk wrote:
Hello
-ryk
Count me in...
LektroiD
ryktnk
PostPosted: Sat Nov 25, 2017 4:13 am    Post subject: Reply with quote  Mark this post and the followings unread
LektroiD wrote:
ryktnk wrote:
Hello
-ryk
Counted !!
An thanks for the PMs so far.
-ryk
Count me in...
Ayab
PostPosted: Sat Nov 25, 2017 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks ryknk
Count me in for a board too Very Happy
Approx how many takers do you need to make a run feasible?
atol
PostPosted: Mon Nov 27, 2017 5:26 am    Post subject: there it goes Reply with quote  Mark this post and the followings unread
Can't afford this at all:
https://www.ebay.de/itm/122825522814?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
ryktnk
PostPosted: Mon Nov 27, 2017 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked Shocked
atol
PostPosted: Tue Nov 28, 2017 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
If anyone wants to sell me one...i can offer 1100€ and Karma bonus points.
Audio files: 20
PostPosted: Tue Nov 28, 2017 3:18 am    Post subject: Reply with quote  Mark this post and the followings unread
There is a work-around to the problem of the clicks:
Drill a hole in the knob of the potmeter of a few millimeter, have a small ball with a spring inserted into the hole.
Than drill 8 dents in the frontplate at the right positions.
Something like the picture below.
my synth
Rvlt
PostPosted: Tue Nov 28, 2017 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess there is a much easier solution:
https://www.musikding.de/Print-Drehschalter-1-Pol-8-Stellungen
They are also pretty small (compared to my other standard rotary switches). Haven't tried them though..
ryktnk
PostPosted: Tue Nov 28, 2017 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also these mini rotary switches look quite small, similar
size to Alpa style pots.
https://www.ebay.co.uk/itm/2pc-4-8-Way-Selector-16mm-Rotary-Switch-15mm-Knurled-Shaft-Used-PCB/112073905103?var=412808673416&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D49480%26meid%3D696bca458b2a4860bde342cc42a8505a%26pid%3D100623%26rk%3D1%26rkt%3D3%26sd%3D112073905103&_trksid=p2047675.c100623.m-1
Ayab
PostPosted: Tue Nov 28, 2017 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ryktnk
Those rotary switches would be great.
Will the pcb fit Eurorack format and run on 12V?
Looking forward to finding my inner Dan Lacksman!!
ryktnk
PostPosted: Thu Nov 30, 2017 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ayab wrote:
Hi Ryktnk
In theory it works on 12v, although I havent tested.
I think some people here have built with 12v
Ayab
PostPosted: Thu Nov 30, 2017 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for info - when I have time I will take a look through this thread.
julian
PostPosted: Fri Dec 01, 2017 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
There are euro units in the photos above, so plenty of people running them in euro format.
Ryk, i would be up for a pair of boards (one with each revision chip)
Thank you,
Julian
ps. if / when the switch is confirmed, i will edit the panel files for it.
For custom cnc engraved panels see - http://www.thebeast.co.uk/cnc/
DANalog808
PostPosted: Sat Dec 02, 2017 12:13 pm    Post subject: 185 PCBs and panel
Subject description: Sequencer
ryktnk wrote:
Hello
-ryk
Hi Ryk,
I am in for 2 sets of PCBs too. I also need a V 3.1 IC to upgrade my existing 185
and I guess you also provide these updated ICs with the new boards too.
I would also pay for two Roland 100 M type panels...
Glad to see you still active on this forum.
Also, I wanted to ask if you would be interested in some new project ideas.
I wrote an email to you but not sure if you still use the old one.
Alfredo
PostPosted: Wed Dec 06, 2017 10:58 am    Post subject: Two sets forma muy please Reply with quote  Mark this post and the followings unread
Hello Míster ryktnk, I would take two sets, two boards and two Pics.
Thanks.
Alfredo
PostPosted: Wed Dec 06, 2017 11:06 am    Post subject: Minimun 5000 pieces Reply with quote  Mark this post and the followings unread
Hello Mates, I found this but the minimun order are 5000 pieces Sad
https://www.google.es/amp/s/m.alibaba.com/amp/product/698591969.html
 Filesize:  105.16 KB
 Viewed:  2228 Time(s)
moket808
PostPosted: Thu Dec 07, 2017 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ryktnk, I'm in for this marvelous sequencer !!
i would love to buy one kit
ryktnk
PostPosted: Thu Dec 07, 2017 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Thanks for the PMs and interest in the PCBs.
Currently 25 !! and counting.
-ryk
masterofstuff124
PostPosted: Thu Dec 07, 2017 10:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
PM sent. Looking forward to this!
now the real question do I build a 5u. Squeeze into a 3u. ???buchla??? Hmmmm anyone planing a panel run?
a100user
PostPosted: Fri Dec 08, 2017 1:03 am    Post subject: Reply with quote  Mark this post and the followings unread
PM Sent for a pair.
http://a100usersplace.blogspot.com/
