M185 sequencer Project - Software Update !!
Page 37 of 39 [975 Posts]
Goto page: Previous 1, 2, 3, ..., 35, 36, 37, 38, 39 Next
onelove
PostPosted: Sun Dec 17, 2017 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
2 x Kits for me also … Pm'd
also are these switches right… I just got a 1000
 Filesize:  60.89 KB
 Viewed:  246 Time(s)
artfx!
PostPosted: Thu Dec 21, 2017 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
2 pcbs here please Smile
I'd love to finally get some Ryk going in my eurorack!
ryktnk
PostPosted: Thu Dec 28, 2017 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the PMs
Haven't answered all sorry, I am away until after New Year.
-ryk
PWM
PostPosted: Thu Dec 28, 2017 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the update!
electrofluff
PostPosted: Wed Jan 03, 2018 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
PM'd for 2 maybe 3. And can I just say I agree with Julian on the least expensive and most easily obtainable rotary switches Smile
ppkstat
PostPosted: Wed Jan 03, 2018 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe we could do a group buy for the slider switches if possible. It seems a much better solution that the rotaries.
Ayab
PostPosted: Mon Jan 08, 2018 6:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
For builds in eurorack format Whoop-John over on Muff-Wiggler is getting ready to design a control panel pcb based on standard rotary controllers (if Ryk's main pcb run goes ahead) - so much less soldering would be involved - a great time saving and probably trouble shooting time saving!.
Of course it is personal preference but I think a well designed panel with rotaries will be really good. Also has the benefit of much lower cost. A rotaries panel is only 2 HP wider.
A group buy for the difficult to obtain sliders is fine as a one off project but the designers of pcbs and panels need to think of longer term supply.
ryktnk
PostPosted: Fri Jan 12, 2018 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi yes I saw that.
It could be a lot nicer and more compact if he used the mini rotary switches
I posted on previous page in the thread.
-ryk
ryktnk
PostPosted: Fri Jan 12, 2018 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for all the PMs in the last few weeks.
I havent replied to all but I have kept a database of all interested people.
As it stands there is interest for 99 PCBs !!
Havent worked out the pricing yet sorry.
PS please note this project is not for beginners, the PCB is quite tightly
spaced, and the wiring to the controls is rather complicated.
-ryk
Ayab
PostPosted: Fri Jan 12, 2018 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes those mini-rotaries could make a great minimal panel set up. Actually I already used a couple of those for a different project.
*edit* Mini rotaries available on Aliexpress for 0.55p per piece plus postage (£3.42 postage for 16 pieces to UK). Need to make sure it is the 8 position type.
If Whoop John and Julian design for the mini-rotaries and a group buy was organised would be great as this would be a size and cost saving and they are widely available too.
If a cheap source for the classic rotaries can be found I would also be very happy with a control pcb and panel for those.
LektroiD
PostPosted: Mon Feb 19, 2018 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Count me in for 2x PCB sets... If switches etc. are available, count me in for those too... Thanks
LektroiD
ryktnk
PostPosted: Wed Feb 28, 2018 2:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
A quick update . . .
I am in the middle of redesigning the PCBs so they
are easier to make and feature a more stable clock, so
it will be a bit longer before they are available.
Also I may be able to offer the kit with 8way slide switches
if enough people are interested.
-ryk
ppkstat
PostPosted: Wed Feb 28, 2018 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
These are great news. Since you're redesigning it please consider putting a reset input.
Rvlt
PostPosted: Wed Feb 28, 2018 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds great!
and +1 for the reset input.
LektroiD
PostPosted: Wed Feb 28, 2018 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll be in for the switches, basically everything x2 (pcbs, switches, etc), especially if there is a eurorack panel coming available... I'm now thinking about upping my order from 2 to 3 (depending on price of course)...
LektroiD
ryktnk
PostPosted: Thu Mar 08, 2018 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Just thinking about the Reset input, could you let me know
exactly how you see this functioning ?
Is it just to reset the sequence, or would it be to reset and stop
the sequence ?
-ryk
Ayab
PostPosted: Fri Mar 09, 2018 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Great to hear that the M185 redesign is underway Very Happy
Personally I think a reset input should be just to reset.
In addition reset and stop would also be useful Razz
Rvlt
PostPosted: Mon Mar 12, 2018 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
A reset input that simply jumps to step 1 when it receives a rising edge of a clock signal would be super helpful. That way you can sync the sequencer properly to e.g. a DAW without having to manually press reset every time you start the DAW again.
ryktnk
PostPosted: Mon Mar 12, 2018 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
To add a reset only input is quite a simple mod to the existing design.
But if it needs to be synced to the a clock is a bit more complex.
-ryk
Rvlt
PostPosted: Mon Mar 12, 2018 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi ryk,
I guess the simple mod is fine, basically it's instead of pressing the reset button manually you send a trigger signal.
I usually send two clock signals to a sequencer:
- one clock signal with the "tempo" (16th, 8th, whatever..)
- and one reset signal (on each whole note, or every 2nd or 4th or so..)
This works well with my MFOS sequencer (where I added a reset input).
Best regards
Lars
ryktnk
PostPosted: Mon Mar 12, 2018 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Here is a circuit you could add to the current design, to
give a Reset Input.
I havent tested it, but in theory should work.
It is just a simple circuit to clamp the reset input voltgage
[presumably 10v] down to 5v for the PIC logic level, which
is then passed to the NXT and PREV lines via diodes.
Give it a try and let me know if it's useful.
-ryk
 Filesize:  71.82 KB
 Viewed:  239 Time(s)
thresholdpeople
PostPosted: Thu Mar 22, 2018 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Woah! just stumbled onto this.. Amazing. I'd be in for a board or two if this is still happening.
elcoco
PostPosted: Fri Mar 23, 2018 4:38 am    Post subject:   Reply with quote  Mark this post and the followings unread
Wow definitely interested in a full set whenever these get going 'Exclamation'
azot
PostPosted: Tue Apr 03, 2018 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk wrote:
Hello
-ryk
+1
Alfredo
PostPosted: Fri Apr 13, 2018 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes ryktnk, we are ready for your kits!
