Pitchbend limiter
Wan
G2 patch files: 46
PostPosted: Mon Jul 19, 2004 12:14 pm    Post subject: Pitchbend limiter Reply with quote  Mark this post and the followings unread
I still have to get used to the pitchstick. One of the things I don't like is the fact that with a large bend range the limits are not very stable. I thought this one out to get a finer control. The center is still not to sensitive to bends as as you bend onward the bend depth gets deeper, so it is a very exponential curve. And then it gets limited to an octave in this example. Are there any cheaper ways to get the same effect cause it cost rather much DSP.
A nice touch is the use of the track and hold module. That trick I found in the factory patches of OS version 1.20. Don't know who made it, but it is a nice one anyway, so thank you whoever you are.
Now when you release the keys the pitch stays on the last bend value received and sometimes that's just the way i want it.
PitchBendLimiter.pch2
The curve and the limits of the pitchstick are processed to react more like a wheel.
 Filename:  PitchBendLimiter.pch2
 Filesize:  1.42 KB
 Downloaded:  781 Time(s)
Grtz Wan
