Rykhaard
Posted: Thu Jul 17, 2008 8:33 am Post subject:
The Liquid Hihat - NEW VIDEO-Dec.1508 Subject description: The description; schematic and hand drawn PCB layout |
For quite some time I had been wishing for a hi-hat sound in which I were able to change it's pitch as well as other aspects of it's sound. Reading through copies of the old Synapse magazine on a site last year, I found the Voltage Controlled Clock circuit.
It occurred to me that in combining a couple of those circuits with the circuit that produces metallic sounds, found in Ken Stone's Cynare Drum Simulator circuit, I could possibly have, exactly what I wanted.
Here, is the schematic for that:
March 0509 - sorry. I've removed it to give myself BACK more upload space. If you're looking for it, email me and I can send it to you.
The only minor trouble that I have had with this circuit, is the External Input (for Noise or anything else that you'd like to put into it). I should have added an attenuator for this input as well. Neither of my 2 white noise sources in my modular, have their own output attenuators and have amplitudes of 10vpp. They are a fair bit louder than the shimmering effect produced by the Synapse CD4046 VCOs / Ken Stone CD40106 Shimmer combinations.
Outside of that this circuit works wonderfully with an incredibly wide range of sound possibilities.
EDIT: Please note! The following PCB layout is NOT IN REVERSE. This is seen top down as the actual PCB IS layed out. I don't drill through my PCBs. I do everything in Bernie Hutchins' "poor man's surface mount".
March 0509 - removed, to give me back upload space.
If you've any questions just fire them off and I'll answer them to the best of me abilities.
Just in case - the slightly larger full version of the scan is available here:
http://www.damian.deathlehem.com/schematic/TheLiquidHihat-PCB-July1708.jpg Last edited by Rykhaard on Thu Mar 05, 2009 7:07 pm; edited 5 times in total |
creatorlars
Posted: Thu Jul 17, 2008 8:42 am Post subject:
| Awesome! With a layout, I will probably build this. |
Rykhaard
Posted: Thu Jul 17, 2008 9:25 am Post subject:
| creatorlars wrote: | | Awesome! With a layout, I will probably build this. |
I'm posting the layout, right now. There're samples from it in the News and / or Design sections of my webpage, as well as the video that I posted recentlly ...... ooog. Somewhere, on here.  |
Joined: Jul 11, 2005 Posts: 4737 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Thu Jul 17, 2008 4:45 pm Post subject:
So Rykhaard,
Would you mind if I did an ExpressPCB layout of this one?
It would mean I'd be able to re-post it as a standard (parts and copper on opposite sides) layout. And also that I'd be able to post the .pcb file should anyone want to order boards from ExpressPCB. We'd also be able to put it up as a candidate for a large run to be sold through the EM store.
BTW, what did you lay the schematic out with? If it was the ExpressPCB schematic editor, it would speed up the PCB heaps, as I could link them for net checking etc. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
Rykhaard
Posted: Thu Jul 17, 2008 9:07 pm Post subject:
| Uncle Krunkus wrote: | So Rykhaard,
BTW, what did you lay the schematic out with? If it was the ExpressPCB schematic editor, it would speed up the PCB heaps, as I could link them for net checking etc. |
WHA'??? OMFG! Uncle! I would be hugely honoured / appreciative if you did THAT! And if by CHANCE it went through to manufacture, I'd be buying 2, guaranteed, even though I already have the 1 running. The extremely wide range of sound possibilities make it capable of much more than hihat sounds only!
I did the layout with Ray Wilson's software which I decided to start using again. I forgot that ExpressPCB has schematic software! It's free to use isn't it? I could convert BACK to that and do the schematic in it for you, if you'd like??? Just let me know!
Wow. I'm just about blown away by your offering to do THIS, Uncle Krunkus!
Please do clue me in, if my redoing it in ExpressPCB would suit everything fine, and I shall.
EDIT: ExpressPCB downloaded and installed.  |
Audio files: 51
Posted: Thu Jul 17, 2008 9:49 pm Post subject:
Okay, it's a deal.
You download the ExpressPCB program and start transcribing the schem into that, and I'll start on the .pcb
Give me a few days to get started, as I've just finished winding my new pickup, and I'd like to test it out first.
Once we've got the two of them close to done, we'll see how they link and sort out any discrepancies. I'll do .1" pitch connectors for everything yeah? (on the board you can always put in pins, or just wire directly, I just think it's a good standard to follow) I'll also do the optional power connector like I did on the MPS. (although I realise only 3 people have actually seen that board so far! )
Like I said before, I actually find it quite relaxing, so I'm happy to do it.  _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
Rykhaard
Posted: Thu Jul 17, 2008 10:05 pm Post subject:
| Uncle Krunkus wrote: | | Okay, it's a deal. |
I'm still in shock!
| Quote: |
Downloaded / installed and I shall start transcribing tomorrow morning whilst awaking!!
| Quote: |
Aww heck Unc! I'm in no rush! Well - at the same time, I AM, but I'm not. I'll start transcribing tomorrow morning. As well, I had been planning on fine tuning my 3 VCOs and 1V/octave sequencer tomorrow as well as testing the LM13600 or 700 for VC of symmetry tomorrow as well. Shall see what I can do. Always takes me at least an hour to wake up though, and that I'll spend with ExpressPCB.
Winding your new ..... duh! Hahahaha. I was thinking TRUCK! Winding? The alternator? Took a moment but finally clicked in.
Being a guitarist originally - could you describe to me the results in winding your own pickups?? (I've never wound, but my adoptive dad had endless patience and wound his own motor, many a year ago. And I thought _I_ had patience!
| Quote: |
That is more than agreeable to me. I've been debating going .1 connectors for my own panel interfacing, to try and neating things up further.
(Have gone .156 for all of my power connectors now. Haha. ESPECIALLY how, having 1,000's of Molex connectors free from work. )
| Quote: |
Drooling over the coming MPS ...... I digress. (Now - what DOES digress mean? Thought it sounded appropriate. lol )
With .1 for pin connectors, I'd likely shift to that as I've been getting used to making all of the pin connections for my power supply connections, anyways.
| Quote: |
Like I said before, I actually find it quite relaxing, so I'm happy to do it.  |
If I'm not rushing, due to being out of time - my studio / electronics shop is my 'escape' area where I relax wonderfully. Very understandable.
Much-o thankees Unc!  |
Rykhaard
neandrewthal
Posted: Sat Jul 19, 2008 7:17 am Post subject:
I'd love a liquid hi-hat too.
I was planning on building a perc synth out of 4 THMPS, but I realized I would be using two of them for the open and closed hi-hats(that's 36 knobs ) when I could just use this instead  _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
Rykhaard
Posted: Sat Jul 19, 2008 8:09 am Post subject:
| neandrewthal wrote: | I'd love a liquid hi-hat too.
I was planning on building a perc synth out of 4 THMPS, but I realized I would be using two of them for the open and closed hi-hats(that's 36 knobs ) when I could just use this instead  |
The possibilities of sound variations with this little bugger are huge! Once I start working on a sequence with intent, I'll shoot another video giving examples of how to achieve certain percussive sound types.
That will help presentation of some of it's abilities all the further.
The MPS - are you speaking of Thomas's new one that isn't out yet? I know I'm wanting 2 of them at least. I'm not worried about knob quantity requirements though. I can't wait for it to come out.  |
RF
Joined: Mar 23, 2007 Posts: 1481 Location: Northern Minnesota, USA
Audio files: 28
Posted: Sat Jul 19, 2008 10:26 am Post subject:
So ummmm..Rych,
If we got a layout from Uncle K I'll bet there would be group buy possibilities. I'd sure like a couple of those circuits in my kit.
bruce |
Rykhaard
Posted: Sat Jul 19, 2008 4:03 pm Post subject:
| RF wrote: | So ummmm..Rych,
bruce |
Durn tootin'! Like I'd said in another thread - (or possibly above in this one - gettin' too old to rem'ber. :lol) - if boards were made professionally, I'd be buying another 2 to go with my 1, for SURE. Having multiple sounds available on call, would be phenominal!!
I'm working on redoing the schematic into ExpressSCH. Almost 1/2 way done then off to Uncle Krunkus.
Even if it didn't go through professionally, if anyone was willing to PnP them, I'd buy a couple from THAT person! (If I had a laser printer again, I'd do that myself. ) |
Rykhaard
Posted: Sat Jul 19, 2008 4:06 pm Post subject:
| fonik wrote: | definetely.
i am thinking of an analogue drummachine for a year now. the liquid HH would be in! |
Part of my monsterous sequencer engine that is currently under construction (2 x Master Dividers (latest version) just arrived for it, from Ken Stone. Major happy there! ). The whole engine will be a drums controller as well as sequenCERS, controller.
I've been wanting a 'drum machine' in my modular for a long time as well. Come ONNNnnnnnn MPS! 2 to 4 Liquid Hihats and 2 to 4 MPSes and I'll be set! (And my Cynare that I have, as well.) |
Audio files: 51
Posted: Sat Jul 19, 2008 11:37 pm Post subject:
These so called "Master Dividers" of which you speak, obtainable they are?
Schematic on Ken's page it is?
So,.........
Rykhaard
Posted: Sun Jul 20, 2008 7:36 am Post subject:
| Uncle Krunkus wrote: | These so called "Master Dividers" of which you speak, obtainable they are?
For some reason, I can't find a direct link to the sub-section for the Master Divider itself - CGS22. from the main modules section - from http://www.cgs.synth.net/
The schematic itself though, I CAN get a direct address for and it is:
http://www.cgs.synth.net/modules/pic/schem_cgs22v2_md.gif
The top panel in my modular has:
- 2 x Master Dividers V1.0 (7 divide by 2 outputs, each, with Clock inputs)
- 2 x Tom Bugs Pattern Generators (1 of them modified to drive my 4 x 1V/octave rotary switch steps, so that it acts as a 4 step sequencer)
- 3 x Clocks (each driving a single colour of a tri-colour LED)
- 1 x 3 input Summer / Inverter
Ken's new V2.0 Master Divider though, gives you 0º, 90º, 180º and 270º phase outputs from each of 4 division. (Except the 1st one, if I recall correct). This will help me in using 1 of them as a Master Clock.  |
Audio files: 51
Posted: Thu Jul 31, 2008 4:29 am Post subject:
Okay,
I've modified Rykhaard's schem to make it a bit easier to layout the PCB, and the layout is well under way. Let me know if anyone would like to check over the new schem.
I'm trying to lay it out as a one sided PCB, so it will be easily transferred for home etching. Man! It's a whole different ball game! I feel like someone swapped the Quickie for the Cryptic on me! Very challenging. I like a bit of a challenge. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
Rykhaard
Posted: Thu Jul 31, 2008 8:21 am Post subject:
| Uncle Krunkus wrote: | Okay,
Send it on over and I can clarify away.  |
Audio files: 51
Rykhaard
Posted: Fri Aug 01, 2008 9:28 am Post subject:
Great amounts of thankyous for doing the restructuring of the schematic, Uncle Krunkus!!
The whole thing looks great! It's provided me with a couple of methods that I hadn't even thought of myself, even though I've seen them done (labelling) in Ray's schematics. I'll be adopting that myself as well!
The only change to be made is the "Range 4" label, on the 2nd CD4046. The Range controls for each of the 2 of them, are for setting the frequency range that each of the VCOs will operate within. Appropriately: Range 1 and Range 2.
Otherwise - excellent!  |
Audio files: 51
Posted: Fri Aug 01, 2008 3:40 pm Post subject:
Yeah I wasn't too sure about how to name the "sections", so I did 1,2,3 for the Oscillators across the top, and 4,5,6 for the ones underneath, and that meant it became the "range" for oscillator 4.
I think I should have left it alone!
I'll go back to the way you had it (VC on Oscs 1&2 + 3,4,5,6) and re-post the .gif.
I also forgot to send you the .sch so I'll do that too. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
Rykhaard
Posted: Fri Aug 01, 2008 8:34 pm Post subject:
Thanks muchlee again Uncle Krunkus!! No worry in sending the gif directly to me. I can just copy / paste / save from the forum, for it.
Once I'm back and have my G.I.M.P.-S.E. completed, I'll be posting a far larger set of samples of the Liquid Hihat to give all a greater idea of some of it's capabilities.  |
loss1234
Rykhaard
Posted: Sat Aug 16, 2008 11:01 am Post subject:
| loss1234 wrote: | hey there
this is exciting. PNP of this would be great!
also. what are we going to have to install in addition to this to fix the attenuator issue you speak of? is that really just going to be an opamp BEFORE the input to reduce the volume? (like a mixer or volume control?)
or even just a voltage divider?
thanks |
No worry now! I realized it later and Uncle Krunkus added it in at the balance control opamp.
When it comes about, if you do a PNP of it - would you care to do a 2nd? I'd gladly pay for it.  |
