The CGS VCO
Page 4 of 4 [83 Posts]
southcitypride
PostPosted: Mon Mar 25, 2013 9:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone built the full version in Frac? I'm contemplating doing it, but not sure if it'll fit very nicely.
billy pilgrim
PostPosted: Tue Mar 26, 2013 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have, fits well in 3u wide. I can upload FPD file if you'd like ?
fluxmonkey
PostPosted: Wed Mar 27, 2013 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'd be interested as well...
www.fluxmonkey.com
billy pilgrim
PostPosted: Wed Mar 27, 2013 7:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
here you go...
CGSVCO-2.fpd
 Filename:  CGSVCO-2.fpd
 Filesize:  2.21 KB
 Downloaded:  413 Time(s)
Solid Rate Studios
PostPosted: Tue Sep 24, 2013 8:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Time to slap some FRAC panels on these bad boys...
Can't wait!
Solid Rate Studios
PostPosted: Wed Dec 04, 2013 12:10 pm    Post subject: Complete... Reply with quote  Mark this post and the followings unread
sonicwarrior
PostPosted: Sat Nov 08, 2014 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
zthee wrote:
Apparently a corrected version of that has been posted @Muffwiggler:
romaindegode
PostPosted: Wed Apr 17, 2019 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys
I need some precisions about tempco
The BOM shows two different ones :
- TEMPCO - PT146 1K 3500ppm
- TEMPCO - 42R2 0.1% 0.25W 15ppm Resistor
I already have a lot of Akaneohm 1% 3300ppm. Do you think it will be ok ?
I was wondering the same thing for the Thomas Henry XR vco and read that from him :
Thomas_Henry wrote:
If you check the exponential relationship, you'll see that 3300 is a better fit. I only used 3500 because that's what I had. Either will work acceptably, though.
Do you think this is the same for this CGS VCO ?
Also, BOM mention 42R2 0,1% 15ppm tempco and the closest one i can find is from elby design : 40R2 50ppm. Moreover, i can't find this in the schematics.
I really don't have a deep understanding of tempcos but i might guess this is just a way to make that 1K 3500ppm to 3300ppm ? So i don't need it if i have already a 1K 3300ppm?
