 Forum index » Clavia Nord Modular » G2 Patches - Completed » Fantasy
Haunting Strings (2 versions)
Page 1 of 1 [4 Posts]
jamos
G2 patch files: 37
PostPosted: Fri Jul 30, 2004 10:01 am    Post subject: Haunting Strings (2 versions) Reply with quote  Mark this post and the followings unread
Here's the final cut - whatever that means - of a string oscillator feedback patch I've been working on.
Aftertouch adds feedback; use the mod wheel, bender, and parameter page A1 to make it sing. The Kill Feedback button will mute the string osc through the Decay control, and thereby kill the feedback loop. Three variations in each version.
The first version (Haunting Strings.pch2) uses three string oscillators and is unfortunately a power suck: I can only get three voices on a G2, or 7 on an expanded. The second version (Haunting Strings-.pch2) uses only two string oscillators, and is therefore less rich but is more practical when used in a performance (14 voices on an expanded G2).
Haunted Strings.pch2
Large version of Rich string feedback pad. Aftertouch adds feedback; use the mod wheel, bender, and parameter page A1 to make it sing. The Kill Feedback button will mute the string osc through the Decay control, and thereby kill the feedback loop. Three v
 Filename:  Haunted Strings.pch2
 Filesize:  2.03 KB
 Downloaded:  1873 Time(s)
Haunted Strings-.pch2
Small version of Rich string feedback pad. Aftertouch adds feedback; use the mod wheel, bender, and parameter page A1 to make it sing. The Kill Feedback button will mute the string osc through the Decay control, and thereby kill the feedback loop. Three v
 Filename:  Haunted Strings-.pch2
 Filesize:  3.35 KB
 Downloaded:  1751 Time(s)
Audio files: 143
PostPosted: Fri Jul 30, 2004 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Quite interesting sounds. I like the first one the best. A definite keeper... thumb up
jamos
G2 patch files: 37
PostPosted: Fri Jul 30, 2004 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, mosc. I was negligent in not crediting you for helping tame the feedback loops; thanks for that too.
Audio files: 143
PostPosted: Fri Jul 30, 2004 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
jamos wrote:
Thanks, mosc. I was negligent in not crediting me for helping tame the feedback loops; thanks for that too.
You're welcome, but huh Question
