Buying a replacement power cable for the Engine
Page 1 of 1 [10 Posts]
cappy2112
PostPosted: Wed Sep 17, 2008 7:06 pm    Post subject: Buying a replacement power cable for the Engine Reply with quote  Mark this post and the followings unread
Where can I get the oddball power cable for the Engine replaced (at least in the US)? Why Clavia didn't put a ground pin on the power cable, but did on the KB versions? The engine has a metal frame too.
Are these found at common electronics stores?
Thanks
Derek Cook
PostPosted: Wed Sep 17, 2008 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't know about where to get your cable from, but in the UK, if a metal framed object is "double insulated" so that no internal live electrical component can touch the frame, then an earth core in the mains lead is not required.
Regards
Derek Cook
www.echoes-music.co.uk
www.purefloyd.co.uk
www.carregddu.co.uk
www.xfactory-librarians.co.uk
www.ex5tech.com
Audio files: 296
PostPosted: Thu Sep 18, 2008 9:06 am    Post subject: Re: Buying a replacement power cable for the Engine Reply with quote  Mark this post and the followings unread
Over here it's a bit like power cords as used for shavers, not sure if it's exactly the same though.
Derek Cook
PostPosted: Thu Sep 18, 2008 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
And I forgot to say that it does remind me of the type of lead old portable cassette recorders (remember them?) used to have.
Regards
Derek Cook
www.purefloyd.co.uk
www.carregddu.co.uk
www.ex5tech.com
Audio files: 296
PostPosted: Thu Sep 18, 2008 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Derek Cook wrote:
(remember them?)
Yup, I had an orange one that I recorded my first electronic experiments with - and it did have such a power cord indeed. I lost most of the tapes unfortunately .. or maybe not Laughing
PostPosted: Thu Sep 18, 2008 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Almost all power cords without ground in Sweden look like the one the goes into my G2 Engine. If you can find a shop that sells converters (airports?) between international socket configurations, you ought to find this kind of cable as well.
Does it look like this?
http://www.thomann.de/se/thomann_netzkabel_euro_2pol_flach.htm
/Stefan
ark
G2 patch files: 31
PostPosted: Sun Oct 05, 2008 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
If it's the same cable that the G2 keyboard uses, then you're looking for a cord with an IEC C7 connector on one end and an NEMA 1-15 connector on the other.
One such product is Hosa model PWP-426. One possible place to buy one is here.
If the connector on the G2 Engine is different from that of the G2 keyboard, then I can't help you Smile
Roland Kuit
G2 patch files: 127
PostPosted: Sun Oct 05, 2008 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
you can use a power cord from the bheringer rotary control, i made this mistake once(switched them) but it works:)
cappy2112
PostPosted: Sun Oct 05, 2008 10:04 pm    Post subject: Re: Buying a replacement power cable for the Engine Reply with quote  Mark this post and the followings unread
Oh yeah- I had one of those a long time ago. Those batteries didn't last more than a year though ;(
cappy2112
PostPosted: Sun Oct 05, 2008 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
No they are exactly the same. That's what happens when I looked at the back of my rack without a flashlight. I was looking at the wrong synth ;(
