Resonant Lopass Gate PCB's (New Batch 4/29/12)
Page 37 of 38 [927 Posts]
Goto page: Previous 1, 2, 3, ..., 35, 36, 37, 38 Next
knob_alchemist
PostPosted: Sun Apr 22, 2012 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok finished, one unit , works fine Very Happy Very Happy
....now I need a good panel for it....suggestions or a FPD panel for eurorack to share???
Thanks!!!!
knob_alchemist
PostPosted: Mon Apr 23, 2012 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
PS:: it's normal that in BOTH and FILTER mode there's a little hum? In VCA mode there isn't....
PostPosted: Mon Apr 23, 2012 10:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
will have to check this.
did you try to touch/move your switch wiring? does this change anything?
Tech Budday at Random*Source
knob_alchemist
PostPosted: Tue Apr 24, 2012 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
No change touching the wiring...no one with this hum?
knob_alchemist
PostPosted: Wed Apr 25, 2012 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
It seems that the hum is the signal of the VCO (more audible whe the VCO is at high range freq) in the LPG...I tried to set the trimmer but no change in the hum.... Rolling Eyes
djthomaswhite
PostPosted: Sun Apr 29, 2012 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello builders and analog tweakers,
I am making some of the Resonant Lopass Gate (RLPG) circuit boards available again. I need to replace some that we're sadly lost in the shipments for the last batch and to replace my personal board stock for my own projects. I have received interest for additional boards recently so I will be taking orders to include extra boards in this replacement order.
If you want boards, please PayPal $15 per board to djthomaswhite@yahoo.com with "RLPG Order" in the subject line and I'll note your order. This cost per board includes shipping (global) via USPS. I always replace any boards lost in shipping, hence this order.
This board is the latest revision, but I will fix the IC ground issue in the mixer section thereby eliminating the need for the kludge to fix the board. Board orders are being accepted from now until May 13th with the new board order being placed on Monday the 14th. Boards take 2 weeks to arrive so orders won't start shipping until the week of May 28th. I know this delays delivery, but I order boards to demand and this method has worked well in the past.
I hope you find the news that I am making this limited run of Resonant Lopass Gate boards available to be good news. This project is a fun one and people from beginners to experts have enjoyed it. Please contact me with any questions or feedback directly at djthomaswhite@yahoo.com
Thank you,
Thomas White
Natural Rhythm Music
http://www.naturalrhythmmusic.com/lopass.html
Thomas
www.naturalrhythmmusic.com/diy.html
Toller
PostPosted: Mon Jun 04, 2012 2:49 pm    Post subject: Bleed Reply with quote  Mark this post and the followings unread
I seem to have the same problem as knob_alchemist (see 2 posts above): the original signal is bleeding through (quietly, yet audible), even when the offset is all the way down and no cv fed in. Especially noticeable in both and filter mode.
Something wrong with the wiring / some kind of crosstalk maybe? Or is this normal?
knob_alchemist
PostPosted: Wed Jun 06, 2012 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi I've see your post and your PM... Your Problem is exactly the same of mine....Maybe is normal and depend from the VCOs??
I've not resolved the Problem, but is not a tragedy, I use a mixer to attenuate the signal of VCO (I use 2 A-110 in FM) and the bleeding is very quiet...
Suggestions? Maybe is normal?
numbertalk
PostPosted: Wed Jun 06, 2012 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Possibly related to the vactrol? If I'm understanding your issue I think this is normal for a vactrol, that it doesn't really turn all the way "off", if you know what I mean.
Starspawn
PostPosted: Tue Jul 30, 2013 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Any left of the last run or a new one planned soon?
Mongo1
PostPosted: Tue Aug 20, 2013 6:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think SynthCube.com has some...
Gary
peng
PostPosted: Thu Dec 05, 2013 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
My main question is this:
What is the "Deep" switch for?
I have read that it is for very large CV voltages.
But I don't get it.
What does it do to large CV voltages?
Anything that an input attenuator couldn't?
This version of the module has CV input attenuators so does that make the deep switch useless?
It practice, it seems to be.
If you have ever engaged this switch please explain why.
(I tried to post to Muff's but that forum is SNAFU lately...again)
muziekzen
PostPosted: Tue Jul 29, 2014 4:14 am    Post subject: Unstable Lopass gate Reply with quote  Mark this post and the followings unread
Hello everyone,
I have built 2 Lopass gates and one of them is very unstable. The offset frequency randomly changes (without any CV modulation) and it happens in all modes (VCA, VCF and both).
I attached an audio file of the issue.
I wonder if anyone has had a similar problem.
Thank you!
g
LOPASS Gate filter problem (Snippet).mp3
 Filename:  LOPASS Gate filter problem (Snippet).mp3
 Filesize:  753.06 KB
 Downloaded:  1035 Time(s)
loydb
PostPosted: Tue Feb 17, 2015 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm looking for a good Euro FP for either 2 or 4 of these babies. Anyone?
sneakthief
PostPosted: Tue Feb 17, 2015 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
4x
http://synthcube.com/cart/forums.html?route=product/product&filter_name=lpg&product_id=224
2x (out of stock right now)
http://synthcube.com/cart/forums.html?route=product/product&filter_name=lpg&product_id=223
Sneak-Thief - raw electrofunk
loydb
PostPosted: Tue Feb 17, 2015 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! Ordered one, plus a panel for my Tabula Rasa while I was at it!
loydb
PostPosted: Sun Mar 15, 2015 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone wired up one of the quad Euro panels? A wiring diagram would rock...
sneakthief
PostPosted: Mon Mar 16, 2015 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
The four LPG's are simply wired individually according to the schematics. You will however need a simple mixer to mix the 4 outputs. This can be done with an op-amp like a TL072 and 7 resistors.
- use a 3PDT on-off-on switches for the VCA/VCF/VCA+VCF modes
- use 2 CV inputs: one directly in and the other with an attenuator
- cutoff and resonance pots are wired using the same orientation as the pot markings on the PCB
- re. mixer: use this, but ignore the red portion:
http://www.cgs.synth.net/modules/cgs04_mix.html
loydb
PostPosted: Wed Mar 18, 2015 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
sneakthief
PostPosted: Wed Mar 18, 2015 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Re. mixing 4 LPG's: also consider using a simpler solution of 4x 10k resistors if you don't mind a signal level drop - which may not be an issue if you're mixing 4 loud-ish signals.
Connect one end of the resistor to the normalization pin of each of the LPG's audio output jacks, then connect all four other ends together at the main mix output jack.
loydb
PostPosted: Wed Mar 18, 2015 7:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I will probably do the full-on mixer, it should be small. I'm also drilling the panel to add the 'Deep' switch to each board.
Ayab
PostPosted: Fri Oct 30, 2015 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Firstly thank you Thomas for this excellent project.
I noticed on someone's build (forget which) that the 1k resistors were white? Just realised must be heat shrink? Extra shielding?
Btw i really like the look of the acrylic panel by knob_alchemist. Does anyone know method of adding simple but uniform annotation to the (back in reverse would make hand painting a bit tricky but I could use a stencil - but v.time consuming).
I am really enjoying slowly comprehending some of this fascinating area (the surface!) which was a mystery only recently. I hope to maybe be of help to some beginners in the future. Sorry about the long post effect of reading the Open letter post - and yes I do have a day off today Laughing
AKMacAddict
PostPosted: Wed Nov 18, 2015 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Really appreciate the information on the mixer circuit, as well as the above solution. I purchased a Quad, and afterwards was told it is missing the components for the mixer output. Apparently the reason was not being able to source the small mixer board (from CGS, or otherwise.)
Now I will be able to make this module "complete". Thanks! Very Happy
intercorni
PostPosted: Tue Mar 05, 2019 3:20 am    Post subject: Resonance
Subject description: resonance starts too early
Does anyone have the problem that the resonance starts too early?
At about one third of the way I'm already in the self-oscillation Sad
Then the signal stops completely.
I use a linear potentiometer for the resonance.
And i try the mod from https://modularsynthesis.com/nrm/lopass/lopass.htm
But it is the same.
Maybe is a antilog pot better?
intercorni
PostPosted: Thu Mar 14, 2019 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
The trimm-pot TP1 does nothing - any suggestions?
The Offset-Pot works fine.
